Question about Likom Futura LD7 17" CRT Monitor
My monitor says Please check the signal cable? I don't get what the problem might me, my monitor is working, because all it shows is Please check the signal cable. All the cables are connected
  • hellokitti0 Jul 20, 2009
    Ok, I am going to admit I know nothing about monitor's, what input setting are you talking about, are you talking about the things that are on the monitor itself. I hope that is what you are talking about. Thanks and what if that does not work, what should I do. I know that the monitor works, because if it didn't I wouldn't see that on the screen. More help would be appreciated.
    Problem Solver:
  • 6 Answers
Try playing with the input settings on your monitor, its happened to me a few times, but yeah just try to do that.
Posted on Jul 20, 2009
Monitor "check signal cable" message
Try first, select input source manualy.
Sometimes, it automatically trys to detect DVI source first.
Jun 19, 2013 | Samsung Computers & Internet
Monitor no signal acer M1640
Check the cable at the back of the monitor and at the back of the computer. If the cables are in tight and you still get the no signal error message you either have a bad monitor or a bad video card in the computer.
Try plugging another monitor into the computer (borrow one from a friend, neighbor or family member if you don't have one). If the monitor does the same thing and shows a no signal message like your original monitor, then the Video Card in the computer is bad. If the monitors works, then your original monitor is bad.
May 02, 2012 | Computers & Internet
I have bought a mew computer with a Sansung screem type LS19A300. It was working normaly and then a message "check signal cable" appeared. I checked all cables and nothing. So we changed the new...
Hi, what was the LCD displaying is that he is not sensing any signal from the computer video port that is why it is prompting "check signal cable". Have you tried checking the pins of your video cable from your LCD? if OK please plug in the cable again when your PC is already open to check that signal will pass thru and lets see what happen. If still the same, try to isolate it with laptop as external video if you have to check the LCD will work with other PC. If the same, replace the signal cable of your LCD if it is removable to further check the problem.
Jun 23, 2011 | Samsung SyncMaster 910T 19" LCD Monitor
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
Have had the nx1932w for 4 years. turned on this morning and it only shows a blue screen with message stating no signal. have digital cable and all other tv's in the house work. please advise.. thank you
If the ViewSonic logo first comes on followed with no signal the monitor is okay, check the video cable connection between the monitor and the computer, if okay the video graphic's card may be the problem,or the motherboard, but this is speculation you will need somebody to check the system for exact cause.
Jan 01, 2011 | ViewSonic NX1932W LCD Monitor
MY MONITOR SHOWS: VGA No signal DVI No signal then shows: Check Video Cable Then: Monitor going to sleep
Try another cable, borrow one, then try monitor in another PC / laptop, if it works then either the software settings for the sleep mode are on or it may be a faulty video card.
Oct 15, 2010 | HP Compaq WF1907 Monitor
Shows "check cable signal" when turned on
If you have not tried using another cable, do so. The cable you are using may be damaged.
Dec 29, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
NO SIGNAL PROBLEM
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
Jun 02, 2009 | ASUS VW192S Monitor
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
Monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
Jan 15, 2009 | LG Flatron 776FM 17" CRT Monitor
Likom Futura LD7 17" CRT Monitor Logo
363 people viewed this question
Top Likom Computers & Internet Experts
David Payne
David Payne
Are you a Likom Computer and Internet Expert? Answer questions, earn points and help others
