Mcm41 we cannot get lids to fit in place so machine will start
I need the lid part B2 for a Krups Master Pro Compact model 703
copy/paste this into your browser: this place has everything!
http://krupsonlinestore.com/product_list.asp?SKW=accfoodprep&SEARCH=&MENU=parts&SELECT=foodprep&PGN=2
Feb 26, 2013 | Coffee Makers & Espresso Machines
Milk top doesn not fit to the stainless steel container
the lid is already in the locked position. hold the base of the lid, and twist the top handle counter clockwise. now place it on the flask and lock it back into place.
Jun 08, 2012 | Miele Coffee Makers & Espresso Machines
How to install the shipping bolt for maytag lat2500 washer?
Hello Phyllis,
The way Maytag did that was by a plastic ring that fit in the lid rim it was deep enough that it would fit inside the top rim of the outer tub cover locking the tub into place. If in your area their is a small independent shop that sells and services Maytag appliances they may have a extra one lying around in the back,if not a peice of styrofoam shaped to fit under the lid and into the tub it would lock the tub into place for shipment.
Gene
Aug 01, 2011 | Maytag LAT2600A Top Load Washer
Installation of lid seal
Typically the lid seal has an opening all around the center and it must face up and fit inside the lid, once is fitted inside the lid cover, lubricate the bottom of the lid seal with soapy water and place it on top of the pump casing. Then apply pressure at the side tabs to snap the lid back in place, note that you may have to use a big C-Clamp to be able to put the lid back on.
May 21, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
How do i fit a new belt in the washing machine
Hello,unplug appliance, remove lid and back plate, place belt on motor and carefully on drum pulley, turn pulley to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Thanks
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Whirlpool stack washer will fill but will not progress to rest of cycle
It sounds like the lid switch is not making contact. It is a magnet located on the lid so that when you close the lid, the magnet pulls the switch closed. Make sure the magnet is still on the lid. If you washer lid will not stay open on most models, the magnet is gone because this is the same magnet that pulls the lid switch closed. If you can find where it goes, find a strong magnet and place it on the top inside rim where the lid goes when closed. Turn the machine on, let fill with water. Once this is complete and the machine should start. Take the magnet and move it around the rim until the unit starts running. If you can't get it to run, most likely the switch it's self is bad. I think you will find the magnet on the lid is gone and the machine will start running once you pass a magnet over the place where it goes. If so you will need to replace the part.
Oct 17, 2009 | Whirlpool LTE5243D Top Load Stacked...
Spin cycle will not engage, however the timer will continue and start the machine at the next wash cycle
open the lid when it starts spin cyce, use a small screw driver or whatever you have that's small enough to fit in the hole under the lid that the tab from the lid goes into. try pushing it in that's a saftey swicth that prevents the washer going into spin cycle with the lid open. it's mostly that
Aug 16, 2009 | GE Washing Machines
Replacing lid on old Maytag toploader
pull the lid back at angle and they will fall into tub.put one side in wet the other side and try to put ball on lid and slide it back into slot for lid ball.may be a hasssle but it will go into place.
Mar 09, 2009 | Maytag PAV2300 Top Load Washer
Broken hinge on reservoir cover for Cuisninart model DCC-2200
The hinge itself is not orderable, but a lid with the element that fits into the hinge was available from Cuisinart the last time I checked. Call 1-800-726-0190 to be sure. It is not easy to put the replacement lid into the right place without breaking the part, but it is possible - you have to put one bar into the hinge, and then pull the other bar just enough to fit it into place without breaking it. If you are out of warranty, the lid will cost somewhere betwen $15 and $20 with shipping.
Feb 26, 2009 | Cuisinart DGB-300 Coffee Maker
Tassimo
Mine sometimes does this but cleaning the barcode reader at the top of the machine (small glass panel) fixed it. Also make sure the water container is seated correctly. If these dont fix it try pushing the water container left right/back front while there is a disc in the machine-mine has started to only work if I push the fitted water container backwards when "brewing".Its out of warranty now so I will make do until it breaks completely. Regards Nicki
May 09, 2007 | Braun Tassimo Espresso Machine/Coffee...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
