Question about Garden
Where is the air intake on a huskvarna 924SB snow blower
2 Suggested Answers
  • 14 Answers
SOURCE: Gas leaks from carb air intake on snow blower?
There are two main things to check. One is the "tickler" at the bottom of the float bowl. Sometimes they can be a little stuck, or need a new seal. The other thing to check is the fuel inlet valve which is located inside the carburetor. It might be fixed with a shot of carburetor cleaner, or even just compressed air. I would suggest removing the carburetor to work on it, but it is possible to do it while it is still on the engine. First shut off, or drain the fuel, then remove the float bowl by turning the nut at the bottom. There will be some fuel present in the float bowl, so be aware of that. When the bowl is removed, the float will have dropped down and be hanging from a hinge pin. Remove that pin along with the fuel inlet valve and shoot some carburetor cleaner into the hole where the fuel inlet valve was. Inspect the fuel inlet valve to make sure it isn't pitted, and replace it if it is. Put it all back together and be sure that you have the clip on the fuel inlet valve onto the tab on the float. Be careful with the float bowl seal too.
Posted on Feb 13, 2015
I have an arien 8524 snow blower. Is there an air filter on this snow blower as my snow blower will not stay running it only starts and runs for about 20 seconds
Most snow blowers do not have air filters. They tend to clog on these units. Sounds like your issues are fuel related. You may try to flush the system with a product called "Start" from Wal-Mart. You will need to follow the instructions on the bottle and try to keep the unit running long enough to run this cleaner through the system.
Feb 13, 2017 | Garden
Gas comes out when I prime the snow blower I took apart the carburetor and that is fine I replaced the fuel line. The manual doesn't show a air filter or fuel filter I am trying to figure it out
snow blowers generally do not have these filters. I guess they assume there is not too much dust around when you are blowing snow,
Dec 28, 2015 | Garden
Where is the choke on a tecumseh snow-king model hsk80
some of these had no choke.BUT they have a primer bulb, you can take the air filter off and use a rag, to cover the intake, and might help pull stale gas threw and give you a better chance of starting. or ask your auto parts store for some starter fluid
Dec 15, 2014 | Garden
Why do you need to remove the jet
You can & should be blowing brakleen
& air thru all the holes
The fact you need the choke partially closed-- tells you something
Your creating higher air velocity,so check for a vacuum leak
(failed gasket) on intake side
May have a failed head gasket also
Nov 15, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Whats the setting of the intake air anf gas screw
this is something you have to play around with , try this way turn all the way in and start to take it out a turn at a time until you are happy with it ,
Apr 13, 2014 | Simplicity L1528E 2-Stage Snowblower...
Snow blower runs rough, backfires
Clean the choke asembly and air filter .
Dec 26, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
The small blower kicks on but the main unit does not power on. Seen the diagnostic code of "3 blinks" and manual said could be pressure switch malfunction. Anyone got any suggestions? Should I go...
Prior to replacing the switch: Inspect the air filter and clean or replace. Make sure both the air intake and exhaust venting is clear of any snow or debris, check it for a sag that could hold water. Inspect all small hose connections from the small blower to the pressure switch for any leaks or cracks, Check any hose that the condensate drains into for cracks. Make sure the pressure switch clicks when you apply a small vacuum on it. Check it for continuity with a multimeter. You can test it by after the small blower starts you take a jumper wire and while the two wires are attached to the terminals; you place the jumper wire between the two terminals. If the unit stays on, you have either a bad pressure switch or a weak inducer blower (the small blower). If possible, remove the air intake pipe from the furnace and use room air for combustion. It will be the pipe that does not go to the small blower. If the unit fires up normally, you have a restriction in air intake or weak inducer blower.
Please rate my answer. Thank you.
Feb 04, 2011 | Heating & Cooling
I have a troy-bilt squall 2100 snowblower that wont start. Primer bulb doesnt seem to do anything. Use of starting fliud in the air intake will get it to start briefly. Removed carb bowl and there seems...
I share your frustration. We just had our first snow fall of the season and my Troy Bilt Squall 2100 would not start or do anything. The snow blower is well maintained and does not have 2 hours use. I use 0-30 synthetic oil and installed fresh gasoline. It is simply maddening to have plunked down close to $500.00 and have a useless snow blower. Trying to get through to Troy Bilt's help line is next to impossible.
Nov 21, 2010 | Honda Garden
My leaf blower will start but wont run when i give it gas it dies. Huskvarna 125B
fuel system needs cleaned
check fuel lines
remove carburetor for replacing diaphragms/gaskets
Nov 08, 2009 | Husqvarna Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
