Question about Magic Chef Refrigerators
Magic chef boxfreezer leaking water under unit
Krazytech
  • 725 Answers
SOURCE: water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Posted on Aug 25, 2007
SOURCE: SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Posted on Mar 13, 2008
  • 9 Answers
SOURCE: refridgerator leaking water
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Posted on Jun 26, 2008
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
  • 2418 Answers
SOURCE: why does my magic chef refrigerator leak water on
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Posted on Jun 30, 2009
What make a magic chef washer leaks only on rinse?
It probably leaked during washer very little by the time it comes to rinse you'll see more water
Jun 07, 2016 | Magic Chef Washing Machines
Having a water leak in the left front of the machine at the bottom. Can't determine cause.
Either there is a leak in drum or one of the hoses and/or fittings under unit is leaking.
Gonna have to roll up your sleeves and check it out.
Mar 10, 2016 | Magic Chef MCSTCW16W2 Mcstcw16w2 Topload...
The water is coming out on the bottom
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 17, 2010 | Magic Chef Refrigerators
We have a ice maker and water dispenser on our magic chef refrigerator. Water has been turned off due to leakage on floor under unit. what is the problem?The unit is a side by side.
I see a lot of cracked lines and cracked inlet valves take back off turn water on and find leak dont be scared just unplug it 1st any questions we are here for you Allbrand appliance lou,ky
Jan 29, 2010 | Refrigerators
Magic Chef DU55CA-01 unit runs but when pump kicks on for discharge cyle water leaks on the floor from the what appears to be the solenoid part. The leaking stops as soon as the pump turns off. What part...
Leaking from drain valve shaft seal. If you just replace the seal it may still leak. Replacing the pump is a lot of work and not really worth it to cure a small leak.
Jan 24, 2010 | Magic Chef 24 in. DU6550 Built-in...
Why does my magic chef refrigerator leak water on the floor
Jun 30, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
MAGIC CHEF WASHER SPINS WATER OUT MAKING CRAZY NOISE & THE WATER GOES OUT ON THE FLOOR. WHAT'S WRONG? DOES THE PUMP HAVE TO BE REPLACED?
could be.pop the top and take off frount cover.run unit and look where water coming from.could alos inspect pump the pully dose come off on those an then drag metal to metal but normaly no water leak.also could be a bad tub seal you would see leaking from under neath
Dec 31, 2008 | Magic Chef CAV2000AWW Top Load Washer
Refrigerators Logo
27 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
