Question about Garden
Toro single stage not blowing snow. the auger seems to be turning fine...
boscia
  • 163 Answers
SOURCE: Transmission on snow blower-sears
most snow blowers are belt driven instead of hydraulic drive. it sound like the belt needs replaced.
Posted on Nov 30, 2008
SOURCE: on my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Posted on Dec 12, 2008
boscia
  • 163 Answers
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Posted on Dec 13, 2008
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
SOURCE: I have a toro ccr 2450 and it seems like the auger
printer carege problem
Posted on Feb 08, 2010
I have a Toro two stage snow thrower that has an auger issue..left just spins as it want the right moves snow....how do I fix...the machine is 13 years old can't find any answers....help please.
The shaft has shier pins that break when an object gets caught in the auger. This prevents further damage. You will need to replace that pin. Make sure you stop the blower, unplug the spark plug before working on it. The pin holds the auger to the shaft. Turn the auger until you see the hole through the shaft and insert a new shier pin.
Dec 12, 2016 | Garden
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
I have a Toro Power max 1323, auger turns but does not throw snow
only a guess of course but if this a 2 stage then you missed a shearboth to the blower if auger runs and it doesn't throw it out
Feb 02, 2015 | Garden
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
Auger rattles so bad on idle, toro power max 926 oxe
bad bearings on the ends , this I would have to see but this is prob it or loose bolts on the auger grab with your hand and see if it is loose anywhere , not running of corse
Dec 15, 2013 | Toro Power Max HD 926 OXE 26 inch 265cc...
I have a honda ccr2450 and with the heavy snow today it clogged and now the auger doesnt seem to turn to speed and is slipping, not throwing snow etc, is this an easy fix. thanks carl
You have a two stage snow blower. The first stage in your auger and they are equipped with a safety shear pin. Consult your owners manual for proper pin or shear bolt replacement.
Feb 26, 2011 | Toro Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
