Hot Point Washing machine VBXR1060VOWW leaking gear oil. Source and repair options?
    Top Expert:
  • Washing Mach... Master
  • 79,024 Answers
Most likely the washer transmission will need to be replaced, that is the only part that has oil to leak out in it.
Posted on Dec 10, 2016
Testimonial: "I thought so, but wanted to hear opinions of others. Any idea of the hassle factor in replacing this? Is it worth it to do so."
  • 1 more comment
  • yadayada
    yadayada Dec 10, 2016
    It is a huge and really expensive job, best left to a professional, just my opinion.
  • Jake LeChien
    Jake LeChien Dec 10, 2016
    I looked up the cost of the part. Does not seem to be worth doing considering the time and cost of the part.
  • yadayada
    I would fix it by of course I am an expert (laugh out loud)
What do i do when my machine is leaking. Oil
you forgot to mention if it is a top loader
if it is then the seal at the bottom of the agitator shaft is leaking water into the gear box
If the machine is not too old it is repairable but if it is then it is not cost effective to repair it
have a technician check it out for a proper diagnosis and quote
Oct 07, 2015 | Washing Machines
We have a hot point washer. That's washing ok spins ok some times. But once machines been turned off and I come to do another load. The machine is full of wTer why???
Maybe the cold/hot water inlet valve has a faulty seat or seal that is allowing water to leak thru to washer despite the valve being closed. Probably need to replace that valve. Look at some of these links on YouTube on repairing or diagnosing water problems:
hot point washer machine fills up with water with machine shut off YouTube
Mar 06, 2015 | Washing Machines
1996 Kawasaki VN 1500 Vulcan Classic oil leak in the lower back of the engine
Hi, Anonymous external oil deposits fall into 3 categories:
1. WEEPAGE is oil that is sweated pass gaskets, seals, o-rings, and crankcase seams, it's covered by dry dust and is normal for older engines with lots of miles, no repair is necessary.
2. SEEPAGE is the same as weepage except the deposit is wet and confines itself to a specific area, repair is optional depending on the owner's cleanliness criteria, the deposit location and the amount of "DRACHMA" he is willing to part with
3. LEAKAGE is the same as seepage except it is enough to drop to the ground leaving a spot. Repair as necessary.
To find the source of your oil leak, start at the point where you see oil and trace its path going up and forward, blowing baby powder from the palm of your hand will help in those difficult to see areas if there is too much oil present then buy a spray can of engine degreaser apply it to the affected area then rinse off with a pressure wand or garden hose, use compressed air to blow off excess water or just let it drip dry, take your bike for a 15 minute ride and check for the leak.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My 1999 vulcan 1500 has an oil leak
1998 Vulcan 1500 shifter seal leak
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
Sep 08, 2017 | 1996 kawasaki VN 1500 Vulcan Classic
Oil leak underneath machine
Possible this can be from the gear box which could have leaked due to a faulty gasket or loose fittings. it is best to clean the area and observe the point of leak to confirm http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Washing machine oil likeage? how to solve? what factors should be considered while repair washing machine?
your washing machine is leaking oil from the transmission. This is the gearing assembly that spins and agitates the washer while in cycle. Factors to consider, 1 cost of the assembly itself (the motor itself is possibly still in good shape) but since you have taken the machine apart to this level I would change motor out at the same time to prevent future repairs. 2 complexity of removal There are some machines that require certain types of tools to remove retaining rings. 3 Overall cost for repair, motor cost, transmission cost, tool purchase (if any) age of unit, is it worth the amount of money being put into it over the purchase of a new unit.
Good luck hope I have helped some
Dave
Jan 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Model 110.92586210 Transmission gear oil leak
You have to remove the transmission and disassemble the clutch assembly. If it is only a very small amount, maybe just a drop or two, just let it be.If it is leaking quite a bit, you can bet not only the transmission seal is leaking, but also the center shaft seals are going bad as well. The transmission doesn't hold very much oil and quite a bit has to leak out before causing problems.
Dec 29, 2009 | Kenmore Washing Machines
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
Washing Machine-hot water source
Most washers require both hot and cold supply. If it has two hose fittings on the back, then you need both hot and cold. I've only seen Asko washers that need just the cold. Even if your washer has a water heat option, it will only heat during a portion of the cycle if the option is selected, it is not a substitute for the hot water supply.
Jul 26, 2008 | LG Washing Machines
WASH MACHINE IS LEAKING GEAR OIL ON FLOOR AND WON'T SPIN THE CLOTHES OUT
If there is oil leaking out, you may have a leaking gearbox.
There is nothing you can do about that but replace the gearbox.
Here is a website link for parts.
http://www.theappliancepartswarehouse.com/seo_indexing.html?m=Whirlpool&s=18500
you can copy and paste this in your web search window
Feb 07, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
