Question about Vizio Televison & Video
My vizio tv model VT420M has no power or lights. I have replaced the power supply board with no result. What do I do next? Is there something else I need to check?
TV model Vizio VT420M Part replaced was :Power supply part number ADTV82421AAD Y9 stamped 715G3196-1
  • yadayada
    yadayada Dec 10, 2016
    And you have verified the power cord is live at the input to the TV?
SOURCE: Power Supply Board
http://www.encompassparts.com/products/?VIZ0500-0502-0102
This is the only place I founf that carries the
part.
Posted on Jan 05, 2009
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 14 Answers
SOURCE: My vizio e371vl will not power on but the orange vizio stays on
Just had one in the shop. It was bad solder joints on one of the resistor packs near the main IC. These packs don't have legs and don't touch the pads. So it is easy to have a bad connection.
Try resoldering all the r-paks on both sides of the board near that main IC. Good luck!
Posted on Dec 25, 2012
Visio E550i-B2 Have sound but no picture. Did a flashlight test and I see an image. Google search results point to bad LED driver but I would like a second opinion. Thanks
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 30, 2016 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Hi I have a vizio vt42om the logo lights up then goes off is that the inverter board or the power supply or just the fuse
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 01, 2014 | Vizio VT420M LCD TV
Service manual
Send your email address to me by Fixya comment, and get a copy of the service manual by return mail.
Jul 13, 2012 | Vizio VT420M LCD TV
I have a Vizio VT420M. When I turn it on by remote, or power button, the Vizio light changes from amber to white, but I get no picture at all OR sound. Do these symptoms sound like a bad power supply,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 25, 2017 | Vizio VT420M LCD TV
My vizio tv will not turn on
I have repaired many of these over the years. Vizio s have regulators on the main board that have been failing causing this problem. You can verify that the power supply is working by the Vizio em-bloom lighting up on the front of the set. Hope this helps. :)
Apr 28, 2017 | Samsung LE40R73BD 40 in. HD-Ready LCD...
No picture or sound.
Hi, it seems you have a faulty mainboard, but the better and more secure option to avoid spending money unnecessary it's to contact directly to Vizio technical support:
Email: techsupport@vizio.com
Tel: (877) 698-4946 Fax: (949) 585-9563
Hours of operation: Monday - Friday: 6 am to 9 pm
Saturday - Sunday: 8 am to 4 pm
Please have your VIZIO model number, serial number, and date of purchase available before you call.
Mar 17, 2017 | Vizio VT420M LCD TV
I have a vizio model vt420m. When I turn it on the screen comes up with vizio logo but it won't go part that. Usually I could turn it off then back on and it would work fine but now it freezes on that...
Hi, it seems a main board issue but for better assistance you can contact Vizio technical support using the information shown bellow:
Dec 25, 2017 | Vizio VT420M LCD TV
Was told my backlight was out on my vt420m and it needed to be replaced
The backligts lamps rarely go out, but the backlights inverter boards that drive the lamps do go out often, you may need better tech that has real experience troubleshooting LCD TV.
Power supply, main board can also cause no lights on the screen. I would get second opinion.
Please read my guide to understand how LCD TV works.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jun 29, 2011 | Vizio VT420M LCD TV
My Vizio VT420M LCD TV has for several months has changed to a dark screen while viewing without any other problems. We always hit "power/cable" on the HD cable box and it would immediately come...
Now the tv u turn on u have a flashes of a picture only few sec. and died have sound left only?Yes,than the 2 long boards call the LCD inverter boards are the causes and the problems.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter board for the replacement.
Jan 15, 2011 | Vizio VT420M LCD TV
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
