Question about Cell Phones
My phone keypad won't allow me to access my phone
  • 4 Answers
Did you have a password that you forgot or you have a keyboard sticky. Try to run finger over each of the keyboard, sometimes it is one key stuck
Posted on Jul 20, 2009
How do I unblock calls on my Panasonic kx-tga470
Step 1 Press the "Menu" button followed by the "#" key on the handheld unit.
Step 2 Enter "217" on the numeric keypad to access the blocked numbers menu.
Step 3 Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
Step 4 Press the key under "Erase" to remove the phone number from the list.
Step 5 Select "Yes" to confirm your selection.
Mar 15, 2016 | Panasonic Lands Phones
My keypad isnt working and I cant unlock my phone screen.
Hook your cell phone up with your computer. The software should allow access to the phone.
Aug 11, 2014 | Cell Phones
My Sim Card won't read in my LG Gm310 phone
Perhaps the sim card was not initialized. Initialization allows you to communicate.
Feb 11, 2018 | LG Cell Phones
Menu button won't work
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Oct 31, 2012 | Samsung Cell Phones
Touch won't work
Aug 15, 2012 | Vizio Tablet VTAB1008
Trying to change my name displayed on the LCD?
It's a trick. When we install Panasonic TDx systems, you have to give the phone users access to programming. If your installer gave you access, you can press PROG and dial **1234 and the system will let you into programming. By default, extension can usually do it, in our case, we allow it on all phones.
If you find the phone that can dial PROG ** (it won't beep at you when you start the sequence), program 004 is extension names. Dial it, press ENTER twice (it moves from softkey 3 to 4) and you'll be looking at extension 101 and a name if programmed. The NEXT key scrolls through the extensions and the keypad pressed X times to get to the letter and the right arrow key to step forward if you need to press the same number key steps you forward. The round ENTER key saves the new name, then pick up the handset and drop it back down to exit programming.
Carl
Jul 01, 2011 | Panasonic KX-T7630 Corded Phone
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
When i press the number 6 button,it goes back to main menu.how can i solve this?
The fault is from the phone keypad.
Switch of your phone, remove the battery, use a phone screw driver to loose your phone to access the internal keypad board. Clean the keyboard with cotton wool and a little liquid carefully, allow it dry and couple the phone back.
You could test the phone before coupling it back.
Best wishes.
Dec 27, 2009 | HP iPAQ 510 Voice Messenger Smartphone
Vx5300 bad board??
you have dirty battery contacts clean with a pencil eraser and that should take care of it
Dec 09, 2007 | LG VX5300 Cellular Phone
Cell Phones Logo
44 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
