Cell Phones Logo
p
pat howard Posted on Dec 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My volume is not working Will restoring back to factory settings help
Marvin
Level 3:
Top Expert:
  • Cell Phones Master 85,242 Answers
  • Posted on Dec 10, 2016
Marvin
Cell Phones Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29055586
Points
266281
It is a question that can only be answered by trying it, there is no guarantee. If you do the reset make sure you back up all your stored files like photo's and phone numbers and other saved data, it will all be erased during the factory reset.
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Need to hard reset my LG.l34c Mobil phone
To hard reset your LG I34c mobile phone, follow below instructions.
Note: Back up all your important and personal data before factory restore. Factory restore will erase all your data and restore device to its original manufacturer settings.
1. Turn the phone off, hold the Home and Volume Down button and then press and hold the Power button too until the device turns on.
2. You will get wipe data / factory reset option
3. With VOLUME buttons select wipe data / factory reset
4. Confirm with Menu key.
GuruAid.com
Dec 19, 2014 • Cell Phones
How to restore back to factory settings
Try powering it up with the power button, and the volume buttons (both vol up and vol down) - all 3 pressed simultaneously. Hold them until it either boots, or gives you the option to restore to factory settings. This is a common method with tablets, but I have not used the pandigital.
Phone is running slow
You need to take a back up of your data and then do hard rest the phone . Below is how you do it .
Menu Path Method: From the Start Screen, press the Menu button and select Settings. Select SD & phone storage. Select Factory data reset. Select Reset phone. You will be prompted again, and select Erase everything. The device will reset and restore the device to the original factory settings.
Key stroke Method Power off the device. Press and hold the Volume Down and the Power Button until you see the HTC logo, followed by white screen with text and a few menu options. Press the Volume Down button to scroll down till you highlight "Factory Reset". Press the Power button to restore your phone to factory settings and also your phone will restart.
Also try not to install more stuff on your internal memory
Thumps up if this has helped .
1helpful
My band new Samsung tablet hung for the first time in less than 24 hours of purchase. I was downloading some the angry Bird and surfing meanwhile... and it froze. Even pressing the on/off button would not...
you should press and hold the power button for about 10 seconds because you can't remove your battery while it hung and try to restore to the factory setting when it can power off
to do factory setting you can follow this step (restore to factory setting will erase all of your data going back to the first time you buy it)
1. press the volume up and power button at the same time
2. when you see the logo appearing release the power button but keep holding the volume up button
3. you can see displayed menu and use the volume up and down to select, then to reset to factory setting please select the option that labeled wipe data/factory reset using the power button
41helpful
9answers
My samsung galaxy ace is pattern locked & i cant open my phone . i forgot my gmail account also
My samsung galaxy ace2 18160 is pattern locked & i cant open my phone . i forgot my gmail account how to open my phone
1helpful
ACER Aspire 3610 Wireless and Blootooth Switches
if you have a system restore disk, restore the settings back to the factory presets. XP System restore could help you, but the restore disk is usually the end result
Volume lock code problem
if you load up your Ipod into Itunes and restore back to factory settings you can adjust that way.
10helpful
4answers
Disabling the mute in the music player
sometimes a gadget just gets confused and restoring factory settings can fix that problem. Go to menu-tools-settings-general-factory settings the phone asks Restor original settings phone will restart press yes it asks for security code. The default code for nokia is 12345. If this doesnt work enter this code *#7370# and the phone will reset. You then set it up as new
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
