Heater puffs and shoots out a smoke cloud with every puff. replaced filter kit and new fuel
    Top Expert:
  • Heating & Co... Master
  • 51,518 Answers
Sorry you need to contact the manufacturer do a search on Google
Posted on Dec 10, 2016
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a a problem with my mr. heater. When I turn it on it puffs
Not knowing what Mr Heater Model you are referring to, I would suggest you call Mr.Heater's customer service line at 800.251.0001.
They have techs that can help troubleshoot your problem.
Dec 30, 2009 | Mr. Heater Portable Buddy
I have a nissan navara 4x4 2.5 di o5 plate i was on the motorway and all of a suddon i lost power then it picked back up again with a puff of smoke it will not let me go over 60mph it will pick up then die...
When were the fuel filters changed.sounds like you have water in the fuel.Drain the tank and try new fuel after changing fuel filter.If it was in limp mode you would not get the revs droping down then smoke then picking up.Limp mode only alows you to do about 40mph.
Dec 29, 2009 | 2005 Nissan King Cab
89 chevy s10 blazer puff smoke out tailpipe when 1st started
A puff of smoke when you start up indicates worn valve seals.That's why all your work didn't fix the problem and it doesn't show a code. It's a pain in the --- job that requires some specialized tools so I guess it depends on how bad it bugs you,if oyu want to fix it.
Jul 13, 2009 | 1989 Chevrolet S-10 Blazer
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
