Question about Samsung Televison & Video
Samsung tv no picture sound is clear. hooked up to Spectrum cable
salt56
  • 373 Answers
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
Posted on Dec 30, 2007
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
Ynothna
  • 44 Answers
SOURCE: Not to computer saavy so please keep it simple. I
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Posted on Apr 16, 2009
  • 105 Answers
SOURCE: hook up to my Samsung 42" plasma TV
Hi There what you need to do is to enable your external vga port this is normally done by pressing your fn ky along with one of the f keys the f key normally has a oblong with a square inside it f4 or f7 seem quite common
If You find this of use please dont forget to leave feedback
Regards AL " Alstech"
Posted on May 25, 2009
SOURCE: No picture from samsung blu-ray to samsung TV
I have a Samsung Blu Ray HT BD 1252 home cinema. This is a replacement for an identical which just stopped working after four weeks. This one is now two weeks old and will occasionally be reluctant to load a disc, recently seven attempts and and forty minutes of loading / unloading etc. It now pixelates or partial picture freeze for a second or two on every BD that we have or rent, yet plays DVDs perfectly. I have tried brand new, sealed BD discs with no luck. Any ideas before I return it to the supplier for a refund?
Posted on Nov 05, 2009
Tv problem- I have a LG model47lb5800. when I turn on the TV it shows a picture and sound for about 3-10 minutes. The TV then goes black flashes a picture intermittently. What's failing?
I had a similar problem in DEC 2017. Curiously the cable company stopped by in a week or so. (I did not call them for service.) It was a "SPECTRUM" truck and not an "OCEANIC" truck. Apparently Oceanic got bought out and the Technician was going around the neighborhood (Honolulu) searching for "Home Broadcasts" I remember reading about WW2 military was looking for homes with RF signals (looking for spys) I'm a retired Army Signal Corps. The Spectrum tech installed a filter on my cable line to prevent our home from producing stray signals. He also told me that my 'analog' TV won't work in JAN 2018 as they are switching to all digital by then. Says my cable will work for a while but expect the company to switch all the cable boxes out to digital. Sure enough my TV stopped working (on analog channel 3) and my cable box stopped sending the analog signal to my analog set. I found out that some of the other outputs worked (HDMI, Optical, etc.) I got the Bedroom TV (bought 2017) to work on HDMI. Picture is crisp BUT I don't seem to have the picture size right. It's smaller than normal (on analog) and changing screen from normal, wide, zoom, etc. really makes it worse. Panoramic is the best so far. Now I notice our older 'Monitor' 42" Plazma (2010?) still works on Chan 3 analog signal. I didn't have another HDMI ($30) cable so I tried using my old DVD Yellow-White-Red RCA cables and found it did not work.
* So.. Short answer; you need to get your TV hooked up to the HDMI output of the cable box. But I would check with your cable company first to see if they can resolve your issue. Now days, they can use a computer (from their end) to correct the problem or send out a service tech.
Aloha, ukeboy57
PS Try rescanning for channels. You will need channel 3 (sometimes #4) If it shows vertical bars then your set can't tune to the cable box. (Just like the old days of "Outer Limits") They do control the horizontal and vertical. You can try to hook your TV directly to the cable without the cable box to get some of the analog and digital channels if your set is less than 10 years old. But the channels are weird and hard to browse. You will need to write down the channels to remember your favorites. Cable remote won't work. But this is just a short term fix. You will end up subscribing to a cable or internet TV service.
Mar 21, 2018 | LG Televison & Video
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
Just bought a new Series 5 Samsung 40" LED TV and we hooked up the DVD and the picture isn't clear. The midrange colours appear halftone dots like in a newspaper
do you have it hooked up through regular video? yellow cables or do you have a HD connection (HDMI, or composite cable, blue green and red) if not upgrade and you will see an outstanding difference.
Mar 29, 2011 | Samsung Televison & Video
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a 37'' Samsung LCD flaf screen tv and the picture all of a sudden is not clear. It is hooked up to directv box and the two other tv's that I have are clear. I also have a Wii hooked up to the tv and...
Try different ports. Use and HDMI cable and see if it is doing on it. If you are using a HDMI cable now hook the connection up with the component cables and see if it is doing the same thing. If it is clear on one of the other ports you have a port on your mainboard that is bad.
Feb 10, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
I hooked up the dvd but I get a picture but no sound
audio cables need to be hooked up as well not just a video cable.
usually red and white and clearly colored on the output side of the dvd player and the tv. input is on the tv output is on the dvd, also if you are using a fiber connection (optical sound) you will need a fiber cable from the dvd to the tv.
Jan 31, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
Mar 15, 2009 | Samsung Televison & Video
Samsung lcd tv LTN1765
check the wires, use a hdmi cable. one wire connects the sound and picture. other than that you will have to use the 3 componets wires and a seperate connection for your sound. example would be audio hook up or fiber optic cable
Nov 11, 2008 | Samsung LTN1765 17 in. LCD HDTV
Samsung HDMI issue
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
I need the correct Settings for Samsung LNT4665FX to view the best picture
these sets are designed for a digital input source, so if you are on an antenna or analog cable it will not look as clear..also if you can set the source for 720p instead of 1080i..it sounds like a lower resolution but 1080i scans 540 lines 2 times to get 1080i and 720p scans 720 line each time,,
Nov 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
