Turn heater on a white Rogers thermostat model number 1f88-300
5 Suggested Answers
  • 252 Answers
SOURCE: my honeywell ct87K thermostat will not turn the heater on
On your thermostat - R is the power in terminal. Y is the cooling out. W is the heating out. (G is fan out). It does not matter which wire goes to R, the other should go to W - if no heat with a call, the thermostat is bad.
Posted on Apr 17, 2009
SOURCE: Replaced the thermostat on a fireplace heater from
Maybe need a Millivolt thermostat ?
Posted on Nov 10, 2011
joselito_578
  • 22 Answers
SOURCE: my white rogers 1f78-151 programmable thermostat is set at 76deg. but will only cool to 79deg.
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Reset the unit by pressing UP, DOWN and TIME buttons all at the same time. The unit will go blank for a couple of second then operate the unit. If this did not resolved the problem contact us directly at 18002842925.
Posted on Sep 17, 2012
joselito_578
  • 22 Answers
SOURCE: connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Posted on Oct 16, 2012
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
WHITE ROGERS THERMOSTAT
Hey, did you ever figure out how to fix this?? Mine is doing the same now.
Dec 02, 2012 | Shaw Robert RS-9420 Thermostat
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Oct 15, 2012 | Heating & Cooling
I need help reprogramming a White Rogers thermostat Please call 352-561-6082
you need to look at the model number and then give me a call back and I will help you fine a way to get you hot water
Sep 08, 2011 | White Rodgers Water Heaters
I need instructions to set a White Rogers IF95-1271 Thermostat
The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Dec 10, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have a White and Rogers programable thermostat (I think that it is an 80 series) We can not find the instructions and I need to check the program. Where can I find directions? If I set a temp. and...
check this link : Don't Know Your Model Number?
after you verify the model number check our website
put the model number on the White-Rodgers Model Number Search/Cross Reference then click submit this will lead you the way on how to secure a soft copy of the instruction manual. If you having difficulty you can call hometechline 18002842925.
Aug 10, 2010 | White Rodgers White-Rodgers 1F85RF-275...
WE need a copy of the instruction manual. Is there a site where we can download a copy? White and Rogers programmable thermostat - 80 Series. Thanks for your help! Fred Skoglund FSkoglund@aol.com
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
