Items not received sec c60f2eec76 - Audio Players & Recorders
Sansui 7070 receiver Hum
Your filter capacitors in the power supply section are to blame and they need to be replaced.
Mar 30, 2014 | Sansui 221 Amplifier / Reciever
I have not recieved my item
Have you contacted Ebay and complained to them that your product has not arrived as of now? eBayeBay
Jun 26, 2017 | PayPal Accounts
How do I know if oys a fuse blown
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it shows INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
Sep 22, 2013 | Panasonic SA-HE70 Receiver
Hello, I have a Sony cdx-gt350mp. When using the front auxiliary in", there is no sound heard. You can see the equalizer display receiving the signals....just cannot hear the music. AUX is...
you might have to enable the aux manual for 350s and 300 says its an item in the setup...first clock then beep then aux ,sub,dim,contrast...ect( Hold the select knob in 3 sec)
Jun 18, 2011 | Sony CDX-GT350MP
How do you set back the % to 100 after a oil change
1. Turn the ignition switch to the ON (II) position.
2. Press the select/reset knob a couple of times until the engine oil life
indicator is showing.
3. Press the select/reset knob for about 10 secs. The engine oil
life and the maintenance item code will blink.
4. Press the select/reset knob for another 5 secs.
The maintenance item code will go away and the engine oil life reading
will reset to 100.
Thank you for using Fixya, and good luck
Apr 13, 2010 | 2009 Honda Accord
How do you set the self timer to 20 seconds?
1. Go to the "Custom Menu"
2. Go to item 16 and set the self-timer duration (2, 5, 10, 20 secs.)
3. Go to item 4 and set the Shooting Mode to "Self-Timer"
You can also set the FN button to do this (item 11).
Oct 11, 2009 | Nikon D40x Digital Camera
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs. and allowing it to reboot. I do this routinely (Once a mo), but did it again. This time it cleared ALL recorded...
Hi ljdubas myname is Mike Houston of DISH Network and I was going over your post and if youare getting the "problem has been detected" and it still comes up after youunplug the receiver and plug it back in there is a problem with the DVR and itwill need to be replaced.
Jun 17, 2009 | DISH Network DVR 510 DTV Receiver /...
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Sep 28, 2008 | Logitech Cordless Mouse
Turns off after 4 secs or so....From Green to Red,
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
Aug 25, 2008 | Denon AVR-1905 Receiver
2001 accent code P1703
P1709 referrs to KICK DOWN SERVO SWITCH >- Open, short circuit DESCRIPTION Detects the point of time when K/D band starts operation to control fluid pressure when K/D band operates. Detection condition 1st or 3rd gear signal is present for more than 5 sec. Transfer shaft speed is greater than 900 rpm Fluid temperature is above 60°C PCM receives an "OFF" signal from K/D servo s/w Check item Harness & connnector K/D servo s/w K/D servo assembly
Jun 11, 2008 | 2000 Hyundai Accent
26 people viewed this question
