How u turn on heat for a white Rogers thermostat model number 1f88-300
shastalaker7
  • 1515 Answers
SOURCE: how to fix a thermostat
Hi, there are many types of White Rodgers thermostats, mechanical 1f56-444 models for heat and cooling, digital, heat-pump stats, ect. When a thermostat goes out, or there is a problem with one, its time to replace them. It is something that techs do not repair do to the circuitry, they are checked to see why they are not working properly, and if they can't be corrected by changing out the batteries or an adjustment, we replace them as the contacts where out along with the circuitry depending on the stat. It would be cheaper to buy a new one then try to repair one even if you could find a place that would even take this on to be honest with you. If you know for sure it is your stat, just replace it. Be sure to mark all wiring connections and colors that are being used on a paper diagram, and take the old one with you to get one to match or the style you like. They are priced from $20.00 on up. I hope this has been of help to you and ask that when rating me, you will be kind as I know you will.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 30, 2010
  • 1015 Answers
SOURCE: My furnace keeps clicking on
Remove the front cover from your thermostat and see if it has a heat anticapator. THIS WILL BE A SMALL ROUND DIAL WITH A CENTRALLY MOUNTED POINTER and a selection of numbers on the outer rim. It should have an arrow on the face of the dial that points one way and says longer and the other way that says shorter.
Check on the rating plate on the gas valve for your furnace and see if you can find the amp. rating for that valve. A usual rating would be .30 or .35 amp If you can find that then hold the dial on your thermostat and move pointer to the closest setting. Put cover back on your stat and turn it up a little to make furnace come on.
Hopefully this will help you. Good luck Thank you and have a happy holidays
Posted on Dec 22, 2010
jyackle5
  • 8197 Answers
SOURCE: I need a manual or
You can get the manual on the link below.
http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6621.pdf
Posted on May 28, 2011
joselito_578
  • 22 Answers
SOURCE: connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Posted on Oct 16, 2012
239gatorac
  • 1779 Answers
SOURCE: Turn on heat for a white Rogers thermostat model number 1f88-300
What is you question??
Posted on Dec 10, 2016
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Oct 15, 2012 | Heating & Cooling
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
I also have a white rodgers 1F80-24 thermostat that all of a sudden the numbers on the display are all broken up. I have changed the batteries.........no luck. I have looked for the exact replacement,...
White Rodgers 1f80 24 - Compare Prices, Reviews and Buy at Nextag ...
Im not sure what your application is but this stat is for a heat heat pump operation or forced air with A/C and heating. If you don't need the heat pump operation and you are using forced air furnace make sure all connections are good as labelled and connected to the proper terminals at both the furnace and thermostat If you installed new batteries and programmed the system without connecting to the sub-base and the numbers are still broken up you should replace it. I have attached a link for you to follow and you can see multiple types of White Rogers on the site home page
Jun 08, 2011 | Heating & Cooling
We have a White and Rogers programable thermostat (I think that it is an 80 series) We can not find the instructions and I need to check the program. Where can I find directions? If I set a temp. and...
check this link : Don't Know Your Model Number?
after you verify the model number check our website
put the model number on the White-Rodgers Model Number Search/Cross Reference then click submit this will lead you the way on how to secure a soft copy of the instruction manual. If you having difficulty you can call hometechline 18002842925.
Aug 10, 2010 | White Rodgers White-Rodgers 1F85RF-275...
WE need a copy of the instruction manual. Is there a site where we can download a copy? White and Rogers programmable thermostat - 80 Series. Thanks for your help! Fred Skoglund FSkoglund@aol.com
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
seconds the thermostat should make a soft click
sound. This sound usually indicates the thermostat
is operating properly. If the thermostat does not
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
