Question about Denon Audio Players & Recorders
MY DENON UPA-F07 HAS TWO LIGHTS FLASHING ON AND OFF.THE POWER AND FUNCTION LIGHT AND SADLY NOTHING WORKS
SOURCE: denon avr2105
See this post:
http://www.fixya.com/support/t421934-power_button_flashing_red
Sounds like the same problem to me...
Posted on May 26, 2008
SOURCE: my denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Posted on Jul 17, 2008
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
  • 4234 Answers
SOURCE: I have a Denon UPA-100 amp as part of a 4 piece Denon 100 set,
THe click you would hear is the speaker relay turning on the speakers. If a problem is detected in the amplifier seciton, the relay will not engage. This is often called protect mode and is done to prevent damage to either the speakers or the amp itself. If I remember correctly, these units have discrete transistor outputs and can easily be repaired. These are not the easiest for access however. I would suggest a trip to the repair shop for this one. Expect a parts cost in the $40 range.
Dan
Posted on Nov 30, 2009
Testimonial: "Thanks Dan, much appreciated."
caroldon
  • 17129 Answers
SOURCE: hotpoint aquaris wml 560, 1) all lights flashing
Possible that the inlet valve is not working or the ccontrol unit is faulty.
Please switch off and when switched on check for the voltage to the inlet valve, if water flows, if not the control panel is faulty.
If voltage is present and valve does not work then the valve is faulty.
Also check the DOOR switch( a safety switch) because if the switch is not working the control panel will not allow the control panel to proceed to switch on motor.
Also check and tighten all the connectors to the control panel.
Posted on Aug 31, 2010
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
I have a Denon AVR1603, recently I plugged computer in AUX connections at rear (not loud) and it kept tripping out. Eventually it tripped and now the the on/standby light fashes but nothing else happens....
The LED flash indicates that unit goes into protection. Check the power transistors, the 0.22 ohm or 0.47 resistors in the output of the transistors.
SAM ANDERSON
Sep 29, 2008 | Denon Audio Players & Recorders
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Hi, The power light flashes on and off on my Denon DND 9000 cd players when switched on. Nothing else lights up or works.
The problem is the power circuit board part number GU-3413. It costs about $200 to replace and can be purchased from any of Denon's authorized parts distributors.
Mar 01, 2010 | Denon Dnd9000 Dual CD Player CD Player
Dan
Nov 28, 2009 | Denon Audio Players & Recorders
Denon DRA397 Panel lock on.
Denon has for some reason removed this function from their user manuals. However The manual does show how to do a manual reset of the unit. This may correct the issue.
With the Amp OFF but plugged in, press and hold the speaker A and B buttons and while still holding them press the POWER button. Continue to hold the speaker buttons for another second or so. The display should all light up and flash at 1-second intervals. If not flashing, try again.
This should reset the unit back to factory state with the front panel lock disabled.
Jul 07, 2009 | Denon DRA-397
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
37 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
