Question about Mtd Arnold Corp 38" /42" Mulch Kits
Misfiring when motor runs it is not firing properly sounds like it is missing, changed oil, replaced carp needle, cleaned of the rotor head for spark.
  • 130 Answers
Your valves need ajusted.you have take to shop or get a book show you how to do it
Posted on Jul 21, 2009
Yamaha fazer 600 1999 misfire under load
If you can QUICKLY touch the exhaust pipe near the head do so to narrow down which cylinder is misfiring. Misfired cylinder will be cold or safe to touch. Do this quickly so you dont blister your fingers. Sounds like a lazy float from storing extended period. This is quite common if you don't fire the engine for months. If the float is stuck you can gently tap the float bowl with a screwdriver handle. Worst case pull the bowl, remove float and clean the float needle and seat. All signs point to a lack of fuel. You can pull the cold spark plug and examine it for signs of fuel...wet or dry?
Apr 02, 2014 | 1999 Yamaha FZS 600 Fazer
#2 misfire fouled spark plug in sunfire
yes bad leads will be one of the faults
run the motor in the dark raise the bonnet look for sparkle trails
on the leads
coil pack could be faulty
compression test will tell if it is a leaky valve
back fire can be running lean or timing
Mar 31, 2017 | 1997 Pontiac Sunfire
My 93 olds cutlass ciera keeps misfiring and stalling, i have change the spark plugs, fuel filter, o2 sensor, maf sensor, and still stalls and misfires any ideas?
For engine misfiring problem check the help links mentioned below. Click the link below to go through the troubleshooting procedure :---- Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Engine Misfire codes for car?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Engine Misfire codes?
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
This will help.
Thanks.
Feb 14, 2012 | 1993 Oldsmobile Cutlass Ciera
I have a 98 honda accord 5 spd it has a 4cyl motor vtech i just need to know how to fix a miss fire in cylinder 2 and wich one is cylinder 2
Cylinder #2 is the the second spark plug counting from the right to left.
EX.Below are spark plug on engine
engine
' (oil cap) '
' (4) (3) (2) (1) '
'_________________'
Your misfire can be cause by couple of things but the cheapest way that you can try to fix your car is to do a tune up by replacing:
1)all spark plugs
2)do a oil change
3)spark plug wires
3)distributor cap and rotor
note misfire can be cause by:
1.bad gas
2.spark plug and/or wire
3.distributor cap and/or rotor
4.valve adjustment
5.injector
6.off timing
7.ECM
8.bad wiring(power, ground or feed line)
Jul 08, 2011 | 1998 Honda Accord
My husband did a tune up on my car yesterday and now it wont start it will turn over like it wants to start but it wont he said that its miss firing we have bought 3 new coil packs and still will not start...
If your car is miss firing and your husband changed the coil packs,the wires leading from coil packs to sparkplugs must have got crossed.This will change car timing which will result in the car miss firing.He needs to go over wiring and correct problem for car to run right.You can go online to autozone.com and type in Info about car to get the correct wiring layout.Your problem isnt the new plugs n wires.Its the wiring layout.
Feb 09, 2011 | Pontiac Grand Am Cars & Trucks
Craftsman rider dlt 3000 throwinng gas out muffler won't start can anyone help.
Turn off fuel and do not try to start because it can shear flywheel key or catch fire.It sounds as if the float needle is not seating {closing}properly and must be cleaned or needle/seat replaced.Check to see if fuel has raised oil level on dipstick,if so you must change oil as well as the oil filter.
Nov 16, 2009 | Craftsman Garden
1997 Jeep Cherokee was an excellent runner until 2 weeks ago. Now it suddenly runs hot and dies. While driving intermittently sputters and miss fires. Check Engine light on. Replaced a few things. Should...
Well the water pump sounds bad....it is a cheap fix at $34.00 and will fix the overheating problem. The O2 sensors start at $63.00...but if you have a "check engine light" on, get it read at the parts store for free and see if the code is for the O2 sensor.
Jul 24, 2009 | 1996 Jeep Cherokee Country
Knocking
sir it seem that you see the nearest autorised dealer or service centre for problem such as: 1. Head Decarbonizing 2. Oil chamber Oil sump filter for choke-up or jam need cleaning or replacement. 3. see for proper igniting of spark from the spark plug good supply of current from ignition coil, 4. check for spark plug's 5. Proper fuel supply & good firing  as you mention your car problem that must be likely to be that the engine head system need to get decarbonized, the oil sump oil filter need to get clean-up for sluggage  if any more quaries you can contact me soon.. till then keep on smiling, happy motoring, safer driving, keep your sweet heart clean & tidy see you soon sir..!
May 08, 2009 | 2006 Mini Cooper
99 5.2 durango :pulled codes for multipe missfire cylinder #5-7
Aloha We have just replaced all of what you have replaced, plus water pump, fuel pump, pcv valve and 02 sensor. Took it to mechanic today we had misfire on 1,2,6,7. Mechanic said that the 99 dodge is known for bad computers, he checked ours and works great turns out that it was the coil. Ours was jumping 1/4 inch and had a orange/yellow spark. it is supposed to have a 1 inch spark and be blue. This has solved our problems after 527 dollars later.
Check the coil!
Feb 26, 2009 | 1999 Dodge Durango
Mtd Arnold Corp  38" /42" Mulch Kits Logo
170 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
