I have a Dynaglo 95c.. I am trying to replace the wick: but the wick assembly will not come off..
I can lift it about 3/4 of an inch up. then it stops upon further investigation I noticed that there are 2 metal pins sticking out in this track that is at an angle... It will only lift to these the top of these pins then it stops and will not come off the base... do these pins fold up or push in?? PLEASE HELP ME... its freezing at night and I cant afford an whole new heater I just barley got the wick and some kerosene... THANKS, Jim
  • Anonymous Dec 10, 2016
    The Dyna-Glo 95C is a RMC, round, white kerosene heater!! From what I've seen the wick replacement procedure is similar on most models...
5 Suggested Answers
SOURCE: release button broke on our kerosene heater
Why want you contact N.E.W. and ask them if they will replase the button?
Posted on Nov 02, 2009
  • 30 Answers
SOURCE: Changing Wick in Kerosene Heater
Here is the complany website..parent group name is GHP group..crazy they don't link DynaGlow more easily in a web search
Posted on Nov 06, 2010
  • 4736 Answers
SOURCE: I have a DynaGlo heater
The person who installed the wick did it improperly. The tails should be down in the tank.
Posted on Jan 20, 2011
  • 4736 Answers
SOURCE: I have a DynaGlo kerosene
Here's a link to an Owners Manual for a Duro Heat unit that is very, very similar to your DynaGlo RMC95C-4. I feel pretty confident that this will help you. After you download and print it compare it closely to your heater.
Hope this helps you.
Posted on Mar 12, 2011
I have Dynaglo RMC-95 in Nigeria and the wick is bad . Where and how can i get replacement.
Most hardware stores and home centers carry wicks for kerosene heaters, in season. Since you know your model number, it won't be hard to find one there.
Jun 27, 2011 | Dyna-Glo Heating & Cooling
I have a DynaGlo kerosene heater, type RMC 95C-4. I need a how too manual, can you help me out?
Mar 12, 2011 | Heating & Cooling
I need a wick sleeve for a dynaglo rmc 95c2 is where I found a wick I needed, looks like yours there too.
Stock # 32225
Part # A47726
Mar 04, 2010 | Heating & Cooling
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
DynaGlo RMC-95-c6
did you soak the new wick a good hour in clean kerosine before you installded it???is your wick in the correct position? it needs to be 5/8" showing when installed in the up most position.very important to soak the wick or it won't wick up fluid as it is suppose to.
Feb 24, 2009 | Corona 23-DK Compact Heater
Flame is too high after we changed the wick
the wick needs to be reinstalled in the raised position
Nov 16, 2008 | Heating & Cooling
Dynaglo heater parts
need to replace wick ajustment knob
Mar 05, 2008 | Heating & Cooling
Wick trouble
the wick is held onto the moving mantle with pointed pins protruding from mantle. remove the mantle assembly and remove wick. then, if wick looks charred black on top, clean top of wick by trimming evenly all around with very sharp scissors; otherwise, use stiff brush... then assemble wick to a location that will be about 1/4 to 1/2 inch higher than when removed. may as well flush out kero tank before final assembly.
Jan 24, 2008 | Corona 23-DK Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
