Question about Denon Audio Players & Recorders
  • 44 Answers
Try these links
Hope this helps!
SEO EXPETS - Increase Search Engine Ranking / Position
Posted on Dec 16, 2007
SOURCE: Denon d-c30 cassette problems
That guy (Dries Hyman) has no idea what is he talking about. I have the same problem with my D-C30, and solution is simple, all you need its change the tape deck belt. (but, its very hard to access it if you going to do it by your self)
Posted on Sep 02, 2008
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Posted on Feb 26, 2009
  • 66 Answers
SOURCE: I have a Denon RC871 Remote not functioning
if the lcd electronics is defect or broken it is not worth to repair this, the price will be to high.
if theire is a loose wire the story is different. also posible that the light is defect maybe best to check this and even replace this little part.
Posted on Feb 16, 2010
SOURCE: Hi, The power light flashes on and off on my Denon
The problem is the power circuit board part number GU-3413. It costs about $200 to replace and can be purchased from any of Denon's authorized parts distributors.
Posted on Apr 01, 2011
Free manual for mosfet phase linear upa424 240watt amplifier
You do have 12 volts connected to the remote connection, correct?
Dec 11, 2013 | Phase Linear UPA424CS Car Audio Amplifier
Hi I just bought 1080 blueray recorder and 6500 samsung tv.hooked up dmi cables to tv to denon amp and blueray to tv .had great picture and sound from denon can only get sound from tv.not sure...
Check your Denon amplifier with other input such as, input from ipod sound to amplifier or any source that provides sound to your amplifier. If you have a built in tuner in your amplifier, Does the sound comes out? If it does then check your dvd setting, e.g 5.1 channel surrounding etc. If there is no sound from amplifier, check your amp with qualified service tech.
Jan 17, 2011 | Samsung Televison & Video
I need a new hi fi system but i still want to use my turntable. can I use a turntable with the denon dm35 or sony cmt-bx70db1?
If your amplifier does not have a ' phono ' input, you need a pre-amplifier for your turntable. This is due to the RIAA equalization of records (see: there are many Phono pre-amps available for sale on the internet from under $15 to over $50. Just Google phono preamp. Hope this helps
Jan 03, 2011 | Audio Players & Recorders
Red power light flashing no sound avr-587
The amp will need service
Depending on where you are I can suggest someone to fix it
Mar 28, 2010 | Denon PMA-100M Amplifier
I have a Denon UPA-100 amp as part of a 4 piece Denon 100 set,
THe click you would hear is the speaker relay turning on the speakers. If a problem is detected in the amplifier seciton, the relay will not engage. This is often called protect mode and is done to prevent damage to either the speakers or the amp itself. If I remember correctly, these units have discrete transistor outputs and can easily be repaired. These are not the easiest for access however. I would suggest a trip to the repair shop for this one. Expect a parts cost in the $40 range.
Nov 28, 2009 | Denon Audio Players & Recorders
My remote light keep flashing, none stop
If you are a technician desolder the audio amplifier Ic and check if the device turn on
Aug 12, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Denon DRA397 Panel lock on.
Denon has for some reason removed this function from their user manuals. However The manual does show how to do a manual reset of the unit. This may correct the issue.
With the Amp OFF but plugged in, press and hold the speaker A and B buttons and while still holding them press the POWER button. Continue to hold the speaker buttons for another second or so. The display should all light up and flash at 1-second intervals. If not flashing, try again.
This should reset the unit back to factory state with the front panel lock disabled.
Jul 07, 2009 | Denon DRA-397
My aplifier Denon UDRA F-10 says "protect"
Blingking Light or Protect usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Denon PMA-100M Amplifier
No sound fromDenon AVR-3801
Is there any indications that you have power at all.
Sep 27, 2007 | Denon AVR-3801 Receiver
29 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
