My Sandstrom SHDFSAT12 does not always respond to my remote, the remote has new batteries and flashes when pressed but there is often no response.
It seems that it is not picking up the signal from the remote, even moving the remote around makes no difference, it also sometimes only records part of a program.
SOURCE: Second remote not working correctly.
i put an extende piece of cable on my antena for second set raised it to same hieght as my tv in rear so ya dont see works great now
Posted on Mar 01, 2009
  • 8457 Answers
SOURCE: remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Posted on Dec 15, 2009
  • 61 Answers
SOURCE: My vtx does not always turn over when starter
we have been seeing a lot of the starter buttons going bad here lately, either the head light won't come back on or the starter won't connect. try spraying wd-40 in above the starter and push button and allow it to snap out do this a few times to get some of the wd-40 to the contacts of the switch. if you get lucky this will clean the contacts and save you the expense of replacing the switch. because it only comes in the complete right handle bar switch assembly.
Posted on Sep 04, 2010
BElectric
  • 1140 Answers
SOURCE: My remote control is not responding. I even put
If the old batteries were dead for a while before you replaced them (or you took too long to switch them), your remote has probably lost the codes for your devices. You will need to program the remote codes again before it works.
If not, your remote is probably faulty - possibly the infra-red (IR) transmitter. You can use a video camera to check transmitters. The flashes are invisible to the naked eye, but can be seen through the view finder on a video camera.
Please rate this solution if you find it helpful. Thanks!
Posted on Nov 02, 2010
SOURCE: Heater has stopped working. 'High Power' Red
I have a red flashing light when i turn on my fireplace not sure ahts wrong or how to fix it?
Posted on Apr 08, 2011
Does any one no the sandstorm Freesat codes for the all for one urc7120 sandstrom shdfsat12
0277,0269,0201. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 27, 2015 | Televison & Video
I need the cade for sandstrom Shdfsat12 for the allow one remote urc7120
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order.Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window.It will help you to find the document easily.
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 26, 2015 | Televison & Video
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
Problems ah59-02303a not working
The remote can be tested--shops use a card which when remote is pointed at and buttons pressed--a strip on the card lights up.
Many digital cameras in a dark or very dim room will react on the display screen in the same way--faint flash will be seen if remote is working.
If remote is tested and found to be good---try it very close to unit--you if no response at all and remote is good have a bad remote receiver in the unit(make sure the receiver lens is not blocked or dirty).
Apr 24, 2012 | Samsung BD-C5900 Blu-ray 3D Player
When I turn on WII it says ''press A to continue''ut nothing happens. I have changed the batteries in the remotes but they do not respond. I have checked the sensor is plugged in.
If you have more than one remote, you may have to "sync" the remotes to your Wii system.
1. Open the battery cover on your remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the cover on SD Card slot on the console and press the "SYNC" button.
3. The lights on the remote should stop flashing after a few seconds. Your remote is now ready for use.
This process must be repeated for each new remote.
Feb 09, 2010 | Nintendo Wii Console
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
