Question about Yamaha RX-V2092
How can I factory reset RX-V2092 - Yamaha RX-V2092
    Habit-Forming:
  • 195 Answers
Press MASTER ON/OFF on the front panel to
release it outward to the OFF position to turn
off this unit
Press and hold STRAIGHT on the front panel
and then press MASTER ON/OFF inward to
the ON position to turn on this unit.
This unit turns on, and the advanced setup menu
appears in the front panel display.
Rotate the PROGRAM selector on the front
panel to select "PRESET"
Press STRAIGHT on the front panel
repeatedly to select "RESET"
confirm your selection and turn off this unit
Posted on Jan 06, 2017
5 Suggested Answers
SOURCE: rx-v2092
Sams Photofax has the paper service manual for $20.00 U.S>
No Efax downloads
Posted on Dec 10, 2008
aparsons89
  • 40 Answers
SOURCE: problem with yamaha rx-c2092
Hi, try to unplug this unit from the wall for a minute or so, It may just need reset. If it still does this I would say that you have a loose wire inside where the power supply is. I would not recommend working on this unless you are computer savvy.
Posted on May 13, 2009
welcomejee
  • 10594 Answers
SOURCE: Looking for remote for this Yamaha RX-V2092
This unit has 2 remotes, main and 2nd room remote.
Both are available with Remote.com
Click that link for price info.
Posted on Aug 29, 2010
  • 7 Answers
SOURCE: I have a yamaha rx-v2092. The unit turns on for
it could be the problem with t108 transformer or with the power on relay circuit eg. zener diode
Posted on Sep 15, 2010
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
I have a Yamaha RX-V2092 with a 7 speaker set up. Purchased new. Everything has worked great until recently. Now the center channel speaker, left front effect speaker & left main speaker short off...
It seems that the main sound processor comes into an error and so seems a fault on the board. Since checking for a component level solution is very tricky as the access is not friendly, what could be done initially is to remove and reset the boards, check for faulty connectors that seems to vibrate and bring in these faults. Check the solde joints of the connector pins on the board. Check and solder the processor IC and the allied circuits. If the fault seems to disappear when the set heats up then you must check using a magnifier.Check the solder on the audio driver outputs of the center, main , front and rear are clean.
If not refer and proceed with consensus as a false move can cripple the set.
Oct 28, 2011 | Yamaha RX-V2092
Aug 29, 2010 | Yamaha RX-V2092
Jan 12, 2010 | Yamaha RX-V2092
No power yo frount speakers
check powersupply or check the amp driver stage voltages
Sep 17, 2009 | Yamaha RX-V2092
Problem with yamaha rx-c2092
May 13, 2009 | Yamaha RX-V2092
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
Rx-v2092
No Efax downloads
May 27, 2008 | Yamaha RX-V2092
Yamaha RX-V2092 Logo
105 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
