Question about KitchenAid KHHC2090S Stainless Steel 1200 Watts Microwave Oven
KitchenAid KHHC2090 - Touch panel no longer working. Is there a fix?
The microwave has been periodically beeping and changing screens for the last week or so. Now none of the touch buttons respond. The vent and light still work, but last night the vent would not turn off so we unplugged the unit. Today, after plugging it back in, the touch screen says, Error Code F9-Q.
4 Suggested Answers
WhIzAtIt
  • 136 Answers
SOURCE: Microwave came on by itself
Yes this is usually caused by the touch assy, but $278 !!!!! Thats kinda steep considering the panel assy is only around 30-60 bucks!!! It will need the touch assy and even possibly the control board, because sometimes the logic IC gets fried and causes "ghost issues" as well.
Posted on Sep 17, 2007
  • 1417 Answers
SOURCE: Hi I have KitchenAid microwave model
hello,
what this code indicate on the screen is that there have been a loose wire connected to the element(heater) of the wave.
what you are to do to fix up this problem is to unscrew the wave the trace the wire down to the element the element is silver in nature or color fix up the wire back to the element and then see if the problem is solve, but if the problem remain then it means that you will have to replace the element
you can get the part at any good technician store around you but note this information make sure that the part you will order for should be same with the old one that need a replacement for easy compatible.
thank you and thanks for using fixya.
Posted on Aug 25, 2010
  • 9 Answers
SOURCE: my KHHS179LSS-3 will not let you control microwave
I was afraid I needed to replace the microcomputer when my KHHS179L touchpad was unresponsive. I was able to use the ADD A MINUTE feature, so I knew the unit worked. There had been a power outage of less than a minute to my home recently (I was unaware of this until I asked the kids if they had done anything to the microwave). I popped around on fixya.com and really didn't find an easy solution-my favorites. I loaded kitchenaid.com and found the answer in the FAQ's. Although the control lock out icon was NOT LIT-apparently, that power surge locked my controls. By holding the stop button for 5 seconds once and then aagain a second time, miraculously, my touchpad was restored> HOORAY!
Posted on Sep 26, 2011
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
How do I change the light bulb on KHHC2090
It looks like that answer is on page 33 of your owner's manual.
If for some reason you don't still have yours, you can download it, your installation instructions, and parts lists here.
You can order parts here.
Oct 26, 2012 | KitchenAid KHHC2090S Stainless Steel 1200...
KitchenAid Microwave KHHC2090
Remove the relay case and gently file the points until clean with a miniture file set from Radio Shack, and spray the points with electronic cleaning spray also available from the same location, try this if new relay won't work.
Aug 01, 2012 | KitchenAid Architect Series II KHHC2090S...
Microwave turns on, on its own, beeps non-stop
This is usually caused by a defective touch pad and it not it is the control panel. Replacement costs for either is usually rather expensive.
Jun 07, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
On button no longer works
Without your brand and model number, it's hard to give specific guidance, but when a microwave won't start, the first suspect is a bad door switch or door switch mount. See this file.
You mentioned that you clean the touch panel. I hope that a cleaning spray was not sprayed directly on the controls or on the oven. That's a big killer of controls.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Contract us if you need more free advice.
Jan 31, 2010 | Sharp R-120D Microwave Oven
Microwave model KHMS155LSS-3 turns self on
I had the same problem with the same model of KitchenAid Microwave. KitchenAid customer service will act like they never heard of the problem, although if you google it, you will find that this is a very common problem. Ask to be transferred to the safety department. After more than 6 months of complaining and several repair attempts (they replaced control panel and switches), KitchenAid finally gave me a full refund. This is a serious safety defect for which they have no fix. The product needs to be recalled, and I am willing to testify that KitchenAid was criminally negligent when this product finally causes a house fire and possibly serious injury or death.
Dec 02, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid KHHC2090S Stainless Steel 1200 Watts Microwave Oven Logo
50 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
