Question about Belling Kitchen Ranges
I have a Belling Richmond dual fuel cooker (electric & LPG) and can't simmer anything on the burners because the flame is too high even at the lowest setting
  • 36 Answers
Most gas ranges and cooktops are set for natural gas at the factory. If the flames are too high this could be an indication the range or cooktop was improperly converted from a natural gas setting to LP, (Liquid Propane) gas setting. Contact your installer or local Gas Company to correctly convert the range or cooktop.
Posted on Dec 10, 2016
Why does my belling cookcenter gas have a very low flame on all burners?
The burners are clogged, switch everything off, clean everything and put back together - optimum efficiency should be back after!
Jun 16, 2014 | Belling CookCenter 151 Dual Fuel (Electric...
OVEN FLAME TOO HIGH ON A A GE CONVERTED TO LP
You should have a pressure regulator between your stove and your propane bottle. It's probably delivering too much propane at too high of a pressure to the stove.. If you don't have a regulator, THAT would be your problem. A regulator set to too high a pressure makes flame too high and flame may even try to blow itself out. I've remedied this by taking a small cover off the center of the regulator and adjusting a screw.. (Not all regulators can be adjusted.) If adjusting isn't possible, I'd suggest a new pressure regulator (for LPG). Note: A regulator for LPG is NOT set up the same as a regulator for natural gas.
Oct 28, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Burner will not stay lit. Push in knob-- flame starts, but will not stay lit as soon as you take pressure off of the knob, no matter how long you hold the knob in. Also, on other burners, I cannot reduce...
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
Jan 15, 2011 | La Cornue Grand Palais 180 Dual Fuel...
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Aug 25, 2009 | Whirlpool SF367 Gas Kitchen Range
I can't get a low flame on my lpg hob. The flame isn't outrageously huge so I think the hob is converted for lpg. But I can never get anything on a simmer, even with simmer mats over the flames. ...
If you remove control knobs you should find a hole where screwdriver can be inserted to adjust the flame failing this ensure correct injectors were installed when converted to lpg
Jul 13, 2009 | Ovens
High flame on Mabe Gas Stove
The gas supply pressure could be too high and it could be worth checking or if your supply isn't regulated, try fitting a regulator. Maybe the regulator is faulty if you have one.
From memory I think most domestic gas appliances need a supply pressure of 11 inches on a water manometer. Butane pressures can become quite high in warm weather (and drop to zero at freezing point).
Perhaps your new cooker is jetted for natural gas (methane). As that fuel gas has a lower calorific value than butane the jets would probably be bigger.
As a temporary measure you could try using a hotplate for simmering. I have a gadget that is two sheets of perforated steel with an air gap of about half an inch between them. It is nicely made with a useful handle and a loop for hanging and when placed over a low gas flame it allows me to place the glass coffee pot on it with no chance of damage.
Someone local could surely make you such a gadget if you don't find an everyday item that could be used. A car brake drum would lift your simmering pan a few inches and tend to diffuse the heat...
In the laboratory at school there was an asbestos pad to fit over the bunsen burner so flasks could be heated more gently.
I suggest you take a walk and look around with different eyes to see what you can find...
Mar 25, 2017 | Kitchen Ranges
Id number for range
The id number is in the right hand oven on the right. It sounds ans though the cooker is a 90 or 100 wide with chef top or fish burner. An instruction bookcan be sent in pdf format by contacting www.britannialiving.co.uk
Dec 21, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
47 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
