Question about JVC Car Audio & Video
JVC RXD201 Has no remote, but dial isn't changing fm or am dials
3 Suggested Answers
  • 86 Answers
SOURCE: Scratchy dials onGeneral Electric AM Fm tabletop radio
both switches need a good ceaning. go to radio shack get some contact cleaner. Make sure the radio is off take off the back spray contact cleaner into the switch while turning them back and forth. wait till dry.
Posted on Sep 14, 2009
  • 4 Answers
SOURCE: Scratchy radio volume dial
Use an electronic contact cleaner. You need to shoot it inside the pot through the openings. Then rotate many times. This will remove oxidation on the contacts inside. If you don't use a contact cleaner, turn of f the radio and rotate many times the potentiomer left-right-left-right ...When you turn it on again, you will see the scratcy sound will be reduced but it will come back eventually. The more often you rotate, the less noise it will make. This is a very common problem, nothing to worry about.
Posted on Oct 20, 2009
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
How do I change the time in my jvc
Assuming its a fairly new model...when tye unit is on..hold the menu button down until it finally beeps..u may have to hold it for a bit..then scroll through options till u find clock...then depress dial button and set time..then hold dial button to set once complete
My dvd remote does not work when i try to start movies
Greetings! Does your TV front panel works? If so, the problem lies surely on the remote control portion. But make sure first that the RC unit batteries are new ones. Turn on any portable FM radio receiver and point the RC unit near its antenna. Turning the dial knob very slowly, press any remote control keypads permanently. The moment you hear an oscillating sound from the receiver speaker, stop turning the dial and start to play with the RC unit keypads to find out if there is any sound changes, that means your remote control unit is emitting an infrared signal and its a healthy sign.! Then the defect is on your TV's remote receiver section, mechanically i. e. cold solder or electrically (defective components). Good luck!
Jul 04, 2011 | Televison & Video
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
How do you set the time for a jvc kd-g3k detachable face car cd player?
Press and hold the SEL button until DEMO appears. Use the up/down buttons on the right hand side of fascia to scroll down to clock adjust, and use the circular dial to adjust the time
Change time on car radio model kd-g220
1. Press and hold "select" on the faceplate until the display changes.
2. Using the up/down rocker switch at the right of the faceplate, cycle through the PSM (Preferred Settings Menu) until you get to "Clock H".
3. Use the dial control (left end of faceplate) to select the hour. Note that it's not a 24h clock, just 1 to 12 are available.
4. Use the rocker switch to select "Clock M".
5. Use the dial to select the minute from 00 to 59.
6. Press "select" to return to regular operation; you may wish instead to use the rocker switch to cycle through other PSM options for the dimmer, scroll and woofer.
If you want more details then you can download the manual from JVC here.
I hope that you have found my posting to be of assistance, all I ask in return is that you return the favour by rating my answer. If you still have not solved your problem then add a comment instead and I'll offer further help.
How to disable demo mode on JVC MX-c220
Make sure the unit is on. Press the FM Mode /Mute -Demo button (right next to the power) press it untill you get to either mono or auto (-for stereo). That will take the unit out of the demo mode. next turn the music jog dial (located just above the preset buttons) untill you get to which ever setting you choose. Hope that helps. ( I can't find the manual on line either- not even from JVC! )
Mar 09, 2009 | Audio Players & Recorders
JVC KD-S15 setup - How do I turn "Demo" Off?
press and hold the sel an itenm (useing the silver button beside the volume dial).....then use the volume dial to adjust ,time , demo alot of others...then press sel button to finish.....this is straight out of the instructions...hope it helps you
Clock set
To set the time press and hold the select button in the centre of the volume dial until the word demo appears on the screen. From here you can change the time by pressing the next track >>I button to select clock h. Use the use the volume dial to select the hour. Use the next track button >>I to select clock m and use volume dial to set the minute. This same procedure can be used to change the dimmer on/off, demo on/off and the amp gain. Have a play around. Hope thjis helped.
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
