Question about Miele Dishwashers
Miele G692 dishwasher not draining - the inlet/drain light comes on and I find that the area under the silver mesh filter in the base is full of water.
When I bail out the excess water and reset the machine it carries on, sometimes until the end of the wash. If I disconnect the waste pipe from the sink and flow it into a bowl, it doesn't happen, which suggests that when there is less head of water it is OK. I have already changed the drain pump though secondhand. Is there anything else to try apart from putting on a brand new drain pump?
  • 16 Answers
SOURCE: Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Posted on Feb 10, 2008
  • 351 Answers
SOURCE: Problem with Miel dishwasher: no water
if the valve is humming and the tap is on it should there a plv fitted to the tap somtimes they fail.i had one today on an asko for not filling.remove the hose from the dishwasher and turn the hose on into a bucket to see if water comes through.the valve could still be faulty.hope this helps.
Posted on Mar 20, 2008
  • 672 Answers
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Posted on Jul 18, 2009
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Hi, I have a miele g977 dishwasher. The inlet/drain light is flashing constantly. I have cleaned all parts and checked inlet filters etc and all is ok. I filled the dishwasher with water from a jug and...
There might be water in the base. take the cicker off and open the small access door ...2 screws.....if there is water in the base soak it up with some rags or a sponge and try it. if more water come in the base there is a leak somewhere. Then you will have to remove the base to investigate....good luck
Feb 15, 2011 | Dishwashers
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Inlet/outlet light keeps flashing on G641 dishwasher - have checked filter and cleared debris. Just completed a wash but dishes not washed or rinsed adequately. Anything else I can check before requesting...
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. See what part of the cycle the unit lights up the fault. If it happens at the very start it is the drain. If it drains ok then fails it is the inlet. If it fails after that it could be any number of things.
Hope this helps.
Jan 26, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
My miele g886 dishwasher intake/drain light keeps coming on. I checked the filter and the non return valve and drain pump. It all seems ok. I read somewhere that there is a drip pan under 2 bottom panels....
the inlet/drain light is a standard fault light and can mean anything without connecting the Miele dianostic software to the unit. This is only available to Miele service techs or service agents. If the light comes on in the first minute then it is probably a drain fault. Try checking the drain spigot at the sink end where the drain hose connects as these are usually the cause of most dishwasher faults.Hope this helps
Jan 16, 2010 | Miele G892SC SS Dishwasher
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Miele Model G 692 SCI PLUS does not start up. It drains water if you put water in the bottom. The Inlet/Drain light flashes. I have checked all the water filters and cleaned any very small particles...
The inlet/drain light also comes on when there is water in the base pan. There is a float switch that triggers this and over time if water has collected in the base pan the float switch can stick. Pull out the dishwasher and tilt it towards to back. If there is any water in the base pan it will come out. To be thorough, put the machine on it's back and remove the base pan (4 screws by the feet), the float switch is a circular plastic casing with a polystyrene float in it. It comes apart for servicing, the float can jam if there is any rubbish in the water.
Apr 02, 2008 | Dishwashers
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Sep 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Oct 03, 2006 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
56 people viewed this question
Top Miele Dishwashers Experts
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
