Question about Boating
TOP PROP SPINNING BUT THE ONE BELOW IS NOT ,WHAT DO I DO?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
Is this a boat or an airship?
Posted on Mar 16, 2017
  • 16,199 Answers
You have a boat with a Z-Drive, and contra-rotating twin props? I wouldn't describe them as one below the other. Or are we talking about something different altogether?
Posted on Dec 10, 2016
    Top Expert:
  • 46,437 Answers
Boats do not have an upper and lower prop . throw it away
My prop stopped spinning I looked all over YouTube and can't find out how to fix it
when the agitator of a top loader stops, it is usually the clutch. It is not a job for a home consumer.
Dec 20, 2016 | Washing Machines
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
My 88 bayliner capri loses cavitation every time i turn. how far below bottom of boat should my prop b.
well first you dont want cavitation. But if you are referring to slippage of prop it is either the prop causing the problem as wrong prop or damage. without knowing more this question is hard to answer. Please explain more for more thorough answer
Mar 21, 2012 | Boating
After a minimal crash the bottom blade is not spinning , but the whole copter is trying to spin.
probably you bent a piece near the shaft and it is stopping the prop from spinning but since the motor is still spinning it still tries to spin the other side of the shaft(the copter)
Dec 21, 2011 | LawlMart iPhone Apps
The tailblade has stopped spinning. It won't go forward or backward, just up and down.
ok take all screws out and seethe three cogs? a small one has unmeshed from the top cog. place the cog back together and then turn it on. try moving the helicopter up a bit. now it should work
Jan 21, 2011 | SYMA Toys industrial 2 Tail Rotor Blade...
My kenmore washer spin cycle will not engage / motor is spinning but not engaging prop to spin out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Kenmore Washing Machines
HI I got a 1993 mainbuilt eagle boat. with a 130 hp honda .also have a 24 inch setback plate. Ihave got the top plate above the prop 2 inches above thebottom and I'm haveing a hard time to get out of the...
I think the prop is too far out of the water. The front of the hull is going to push the water away from the transom until you get lift. If you consider the prop is just below the planing fin you need push, not cavitation. With the setback you are actually lengthening the boat and you have a void of 24 inches of water before the hull starts to throw the water out of the way.
Aug 04, 2009 | Boating
Trolling motor will not spin with out being turned by hand.
Take the prop off and make sure the pin that goes through the shaft is in place. The prop could also not be sitting on the pin proper.
Nov 29, 2008 | Humminbird 575 Fishfinder
Need to replace belt
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Jun 30, 2008 | Dryers
Trying to install dryer belt
Boating Logo
560 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
