Question about GE Dryers
GE clothes dryer model DHDVH52 shuts down due to overheating
  • GE Master
  • 20,941 Answers
Pull the machine out and remove the pipe to the wall. Look for fluff build up at the exit of the machine and on any bends.Also that the flap on the outside is opening OK and it is not blocked. Birds will sometimes build nests in them.
Posted on Dec 10, 2016
    Top Expert:
  • GE Master
  • 52,126 Answers
Clean the vent and lint trap /screen
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
How do I identify what part needs to be replaced in my GE Dryer Model DHDVH52 that squeaks the entire time it is drying?
Have a read through this:
http://homeguides.sfgate.com/fix-general-electric-dryer-squeaking-76276.html
There are a lot of videos on youtube about squeaky dryers, but by the article it looks like your belt is going
Mar 22, 2015 | GE Dryers
Where is thermostat located on ge dryer,starts hot then it gets cool
Dryer possibly overheating due to plugged vent. They will go into a safe mode and shutdown the heater if not enough airflow. Results in starting hot but ending with a cold load of clothes! Check the belt to ensure the dryer fan is working and that the drum is properly rotating. If OK and the vent is clear then check the thermostat. Depengin on the type (Gas vs electric) there are a number of limit thermostats as well as a main thermostat. Likely you have a a limit switch kicking in to shut off the heater. Normally from lack of airflow (plugged vent, fan broken, etc...) Once unit cools down will start back up but shut down again once the heater comes on. Also check to see if the heating element is shorted to the side of the metal case. Will heat up and be intermittent.
Jun 10, 2014 | Dryers
Error code E01
Models covered in this error code table :
DBVH512 DCVH515 DHDVH52
EEPROM is in the control board. Here is the part number WE4M385
Here are instructions to replace it. d9f57bce-8333-45b0-9402-b672a600df28.jpg
Jan 31, 2014 | GE DCVH515EFWW Electric Dryer
I have a loud sqeek in my GE dryer. I am guessing it is either the drum bearing, or the bearing/pulley on the tensioner. It sounds like its coming from the tensioner, but i cant get to the tensioner to...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 25, 2011 | GE Dryers
Correct install of propane kit
perhaps it requires wet clothes to function properly .
Dec 25, 2017 | Dryers
Clothes Dryer Break Down
Check your dryer vent and lint collection area for clogs, make sure there is no kinks in the dryer hose and the one way vent outside your house is not blocked. Your dryer is overheating and shutting down due to a thermal fuse that is on a timer and takes while to reset.
Mar 11, 2009 | Frigidaire Dryers
My DBSR453EBww dryer shuts off before the clothes are dry.
Possibly the motor is overheating due to lack of ventilation, or the lint filter requires cleaning, make sure the outlet is clear at the rear of dryer, and that the vent hose (if fitted) is not kinked.
You could also have a problem with the motor itself which is causing it to overheat and the cutout is stopping the motor from working until it cools down enough to start again.
Plz rate my solution.
Thanks.
Jan 03, 2009 | GE DBSR453EBWW Electric Dryer
GE clothes dryer,model DPXR483EA1WW
Well this morning I got up and pressed the start button on my dryer and it's been working eversince. Thank-you I will contact you if I have any more problems. Jessica
Jul 18, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
47 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
