Question about Wurlitzer Audio Players & Recorders
Wurlitzer 2204 jukebox having issue when selecting songs. Select D8,D19 will play. Select D12,D23 and B25 play. Select D8 again, it plays another random song. Other times it does not play anything.
  • 195 Answers
SOURCE: Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Posted on Feb 27, 2009
SOURCE: CD palyer will not play all Songs
It sounds like the CD has to be initialized, so the jukebox knows how many songs are on the specific CD.
To initialize a CD, go into service mode, input code 31, then index the cd number (two digits), then hit "popular". return the jukebox to play mode.
The carousel should scan and load the CD you initialized, and then return it to it's slot.
It should now be able to play any song on the CD you select.
Posted on Mar 21, 2009
SOURCE: Jukebox won't play selection, selects cd's 1-100 in order
Dear Amanda, Here is the manual,
Try re-programming your juke box per the instructions in the manual.
If you will e-mail me at deeddawg@bellsouth.net , I will E-mail you the 100 page manual in PDF format.
Gary.
Posted on Aug 17, 2009
SOURCE: Trying to figure out my NSM Galaxy CD jukebox
when i put 50 cds into my nsm galaxy juke box thay get stuck in the rack and will not play .it will load about 39 and play any more and thay seem to stick
Posted on Feb 21, 2010
  • 195 Answers
SOURCE: need manual for Wurlitzer jukebox 1015 45
I suggest that you check out the Victory Glass wedbsite for a manual.
www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Posted on May 13, 2010
My cd-carnegie has no money changer, it is on free play. It won't allow me to play selections any more.
Possibly the battery is dead in the control unit. When the memory is lost, free play is too. You will need to locate and replace the battery, then re-program. For that you will most likely need the manual. You will have no problem finding a manual on line.
Feb 04, 2013 | Wurlitzer Jukebox CD Player
After making a song selection, the device attempts to play the CD. The CD begins spinning then stops and does not play.
Troubleshooting procedures are different depending on which player system is in the machine. I can help with troubleshooting over the phone and can repair any on the components insdie the machine. Please email tech@wurlitzer-ohio.com.
Aug 19, 2011 | Wurlitzer Jukebox CD Player
Only plays one song at a time; not through entire cd
This is not a problem, the machine is supposed to play only one song at a time.....If you want to play the entire CD at a time, you must first program the machine for "Album Play" and then select the disc number followed by "00". Refer to your manual for instructions on programming album play. PS I sell manuals, tech@wurlitzer-ohio.com.
Feb 05, 2011 | Wurlitzer Jukebox 1015 One More Time...
2900 Keeps playing records
THE WURLITZER JUKEBOX WILL CONTINUE TO PLAY SONGS AS LONG AS ONE OR MORE, SELECTING PINS (THERE ARE 200 IN THE 2900 ONE FOR EACH SONG. THE PINS ARE IN LOWER SECTION OF THE CASE. BETWEEN THE SPEAKERS , AND LOWER DOOR.)
REMOVE LOWER BACK DOOR. WATCH THE ARM THAT STOPS ON THE NEXT RECORD, BECAUSE THE PIN IS UP. AFTER STOPPING ON THE PIN, THE ARM PUSHES THE PIN DOWN. THAT IS THE NORMAL OPERATION. IF THE PIN, IS NOT PUSHED DOWN, IT WILL PLAY THAT OR ANY OTHER SONG THAT HAS A PIN IS RAISED UP. THE PINS ARE THE MECHANICAL MEMORY FOR THAT JUKEBOX.
TURN OFF POWER, ==PUSH ALL PINS DOWN== THE SONGS WILL STOP PLAYING. THEN MAKE A SONG SELECTION. THE ONE PIN WILL POP UP THE MACHINE SHOULD PLAY THAT SONG.
WATCH THE ARM THAT STOPPED TO PLAY THE SONG, PUSH THE PIN DOWN. THAT IS THE SEQUENCE OF THE 2900 MACHINE,
WHAT CAN GO WRONG IS AS FOLLOWS. ==THE ARM DOES NOT PUSH PIN DOWN== THE ARM MISSES PIN== THE ARM NEED OIL, IT IS NOT LUBRICATED.==.
Mar 08, 2009 | Wurlitzer Jukebox CD Player
Mar 05, 2009 | Wurlitzer Jukebox CD Player
Song Programming
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Hello I just recently bought a wurlitzer 2204 jukebox at an aution I cannot get it to play the records the belts are turning, the lights are on and all the blast are lit not sure what is going on, the...
First thing's first.
At power up is the turn table turning? Is the drive motor turning? If so then the jukebox thinks it is playing a record. What happens when you press the cancel button on the back of the machine?
You should check the fuses anyway. Make sure they are the RIGHT value or you will just end up frying your jukebox if you get a serious short.
Dave F.
Nov 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
64 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
