Question about Blue Flame Heating & Cooling
Just installed a 30,000 btu Mr Heater blue flame heater last night, worked perfectly. This morning the flames and pilot light are burning mostly orange. What could be causing this.
  • 2,992 Answers
That is a bad air/fuel mix... could be anything like clogged orifice or just needs to be adjusted.
Check out your warranty support first... and keep in mind poorly burning gas appliance can be EXTREMELY DANGEROUS.
Consider putting in carbon gas detectors in addition to a liberal sprinkling of smoke detectors!!
Be safe
Posted on Dec 10, 2016
  • PamKell
    PamKell Dec 10, 2016
    We cleaned it and it's still the same. We have smoke detectors, going to get carbon monoxide detectors today
  • 3081 Answers
SOURCE: pilot flame burns above pilot tube in propane
Hi it there a leak on the pilot causing it to burn that high can you adjust the pilot gas going in to the pilot ?
have you cleaned the pilot injector out or is the hole in the injector too big
Posted on Jan 25, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: Vent Free Blue Flame heater: shuts off
Sounds like a gas pressure problem. Have your gas company check the pressure.
Posted on Feb 01, 2010
  • 3081 Answers
SOURCE: I have an Enerco Group 30,000-80,000 BTU heater
HI clean the burner , and the air ports on the burner clean the injector remove all trace of soot and dust in needs a good clean see if that works also clean the pilot
Posted on Feb 03, 2010
  • 674 Answers
SOURCE: have a comfort glow heater ventless natural gas.
Look for a small hole or two in the part the pilot flame comes out of. These may be partly blocked. They allow air to mix with the gas for the pilot.
Posted on Apr 06, 2010
  • 3081 Answers
SOURCE: heater pilot light flame is high and middle brick
both need a clean pilot is blocked hence high flame , both need a clean could try blowing then out with a air line , or can of air or just clean injectors on both.
Posted on Jul 26, 2011
Testimonial: "great thanks for your time"
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
The heater ignites well, but if it gets a clear blue flame (and it burns very quiet), the thermocouple will glow red and the heater stays on, but when it gets a opaque blue flame (it makes a sound when...
I would start by replacing the thermocouple. It is suppose to keep the gas valve open when in operation. If the mercury in the thermocouple dries out it won't keep the gas valve open and thus the flame goes out. If that does not work then you have a gas valve problem.
May 05, 2017 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My 30,000 btu Blue Flame gas wall heater wont stay lit, pilot light stays lit but the blue flame went out and had smell of gas I shut off the gas supply but, dont know what is the problem thanks, marty
you could have a overdraft problem causing your flame to go out. check your draft setting at the burner and make sure it's not open too wide. If it is, simply close it it slowly and make sure that the flame remains totally blue.
Nov 27, 2010 | Heating & Cooling
Feb 03, 2010 | Heating & Cooling
Pilot flame burns above pilot tube in propane heater. the sensor does not register. the pilot top of the tube shoul glow red. I have cleaned the tube, in few occasions it has lit and worked for above 10 to...
Jan 25, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light flame is mostly yellow. LP gas
Thr thing you need to do is take the pilot assembly all apart and blow the dust and dirt out of it.
After burning for many, many hours the air that is move up through the pilot assembly leaves dust and dirt which plugs off a bit of the air and makes the flame run rich. Meaning that it does not get enough air mixed in for complete combustion.
When you clean it you will see the dirt and dust com out of it.
Reassemble carefully just as you took it apart and it will be back to working great again!!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 23, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Oct 20, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
83 people viewed this question
Top Blue Flame Heating & Cooling Experts
Paul Carew
Are you a Blue Flame Heating and Cooling Expert? Answer questions, earn points and help others
