Question about The Music
Hi, mics inputs are not working,thought it was the mics themselves,bought new ones, but not working either, so must be the input. the 2.5 fuse,is in tact. Could it be the whole electrical board? .
  • 15 Answers
SOURCE: Korg pa800 mic input makes funny noise
First turn the unit off then rotate the input level volume control. If it feels loose pull up lightly on it as you do this. Also rotate all your controls that you don't normally use a lot. Chances are the pots are dirty. If that doesn't help you might want to check all the connectors inside the unit if you feel confident enough to go poking around. Other wise I suggest that you find a shop that will fix the problem. If you do go poking around make sure the units unplugged and that you have grounded yourself against static discharges.
Posted on Jan 07, 2009
SOURCE: Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
Posted on Feb 07, 2009
rockdiarylv
  • 27 Answers
SOURCE: plugging line level into my crate TX15. all inputs sound distort
guitar amps are all set to a low Z resistance configuration. wich are made for guitar only. make sure you are using the right cables.
you need sheilded guitar cable not unshielded speaker cable in many cases these cables look exactly the same. look at your cable look for the words speaker or instrument. you need the instrument cable. if you still have that problem. then you may just not be satisfied with the quality of the amp it self.
Posted on Feb 27, 2009
SOURCE: Hi i have djx 750 and i have connect the master
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Posted on Dec 27, 2009
  • 5603 Answers
SOURCE: Roland AC-60 Amp input impedances ?
I will solve the mystery...
The impedance varies depending on how you connect. It would be too complicated to explain the impedance to the average person.
From the schematic we have the TRS 1/4 inch jack having basically 100K and parallel 220 pf cap to ground EACH signal line and 10K resistance between. (The TRS jack if used disconnects the XLR and its components)
If one uses the XLR jack, one has an ADDITIONAL 100K each side in parrallel to ground PLUS an ADDITIONAL 2.2K resistor shunting between.
In ADDITION to the above, there is effectively 160K ohms to ground each side that is the input resistance to the input OP-AMP.
The effective impedance will depend on how and where you measure it.
Not sure what peizo you are using... For one on wife's violin we go into a X2 wireless which has about 1.6 Megohm. The receiver of course is fairly low impedance drive to the amp.
For the violin (Autolycus) pickup and others, severe distortion of the waveform existed when run directely into most amps and of course long cables worsened it at the high frequencies.
Posted on May 20, 2010
My Behringer PMP1280S INPUT Chanel 1 is no longer working, after pulling out the mic XLR plug whilst the amp was still turned on.
You should be able to unplug a mic from the xlr input with the unit on with no problem.
I beleive the problem is that the xlr input jack has one or more legs broken off the board. If you dsassemble the board and resolder the three legs to the board you'll probably fix the problem.
Dec 01, 2015 | Behringer Music
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
I have a new Peavey XR1220P powered Mixer purchased March 31/12 with no manual. I have hooked it up, but have one problem to solve. The low impedance inputs are not sending sound to the main speaker
Where is the gain set for that input channel of the low impedance mics? If you have an unbalanced Hi-Z input sharing a channel with a low Z balanced microphone They are sharing the same gain stage op amp- in which case an unamplified microphone loses.
Apr 01, 2012 | Music
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
I just bought a Behringer K3000FX amp and it sounds GREAT with my keyboard. However, just bought a Shure SM48S voice mic and it just doesn't come thru the amp with much volumn...have to turn amp
Greetings! Ok, your amp has an XLR (3-prong) Low-Impedance input on Channel 1 for a Mic. All the other inputs are 1/4" High Impedance inputs, which are for instruments and/or other High Impedance items including low quality High Impedance Microphones. The SM48S is a high quality Low Impedance microphone, so if you use it with a 1/4" plug, it will be in a High Impedance channel, and will be very LOW in volume in comparison with everything else. So, you must use an XLR (3 prong) cable from the Mic to the Channel 1 input on your amp. That will do the trick. Good Luck with your new amp and Mic!
Dec 02, 2017 | Behringer Ultratone K3000fx 300w Keyboard...
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
When my phantom power is turned on . my condensing mic isnt working . at first i thought it was my mic . but then i got a new one and it still isnt working . what is the problem
HAve you tried a different lead? Try a friends mic that you know works on your mixer. Its usually a process of elimination. You substitute a known working one and see what happens. Is the little LED lighting up when its turned on?
Feb 13, 2011 | Mackie ProFX8 Professional Compact Mixer
Can't get my XLR cord with mic to work in either 1 or 2 inputs. But my guitar works pluged into the inputs. Cord and mic is good.
Check to make whether your microphone requires phantom power. If it does you must use a balanced mike cable. Check page 31 of the owners manual for input settings and page 79 for phantom power settings. The manual is here:http://s3.amazonaws.com/samsontech/related_docs/H4_manual.pdf
Aug 15, 2010 | Zoom H4 Handy Recorder
I just bought a Fender VF3 electric violin. It
The piezo pickups for violins REQUIRE a high impedance input preamp.
The measured impedance of My wife's violin is on the order of 2 megohms.
It sounds like you are having cable connection problems. If you don't have a preamp right at the vilin, then use a VERY short high impedance instrument cable.
Most of the Focusrite mic preamps I looked at had input impedance around 5K ohms which is unsuitable for the piezo pickups.
Here we use an Autolycus pickup on an acoustical vilin and an X2 wireless system. The transmiter has a very high input impedance and the resulting system sounds like a violin.
Some amps themselves DO have a high input impedance, but many designed for guitars do not. Long cables, especially low impedance ones, load the piezo pickup with capacitance which clobbers the high frequency response.
Nov 12, 2009 | Music
Jan 26, 2009 | Roland Mv8800 Production Studio
Music Logo
15 people viewed this question
Top The Music Experts
drivealot
Kyle Steven OHare
Kyle Steven OHare
gbob59
Are you a The Music Expert? Answer questions, earn points and help others
