Question about Keurig Coffee Makers & Espresso Machines
Keurig 2.0 a light comes on when plugged in, nothing else happens, machine about 6 months old.
Need a Canadian number to call about faulty 2.0 model. Light comes on nothing else happens when plugged in
SOURCE: heating light stays on
I contacted Keurig at 866-901-2739. Based on my serial number, I was still within my 1 year warranty. They determined that my heating element was bad, based on the fact that the the area above the power cord was not at all hot, which it would be if it was truly heating.
My new machine will arrive via FedEx in 3 days!
The Keurig rep did also mention that the heating elements are sensitive to hard well water, which I have. They have seen issues where hard water requires you perform more frequent de-scaling of the brewer, depending on water hardness. Alternatively, we may switch to bottled water.
Posted on Aug 21, 2008
  • 60 Answers
SOURCE: single cup keurig brewer. machine heats up but no
Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
SOURCE: My Tassimo machine lights up to heating point, but
Try cleaning the area where you place the pucks. This area can get clogged with loose grounds and especially milk from cappacino pucks.
Posted on Jul 14, 2010
SOURCE: I have a whirlpool 6th
f13 is a problem with the door lock, I have the same machine and it takes 4 minutes for the door latch to open and if it dont in the 4 minutes F13 comes up and the machine will go off and not start again.
Posted on Oct 21, 2010
alicantecoli
  • 22306 Answers
SOURCE: Peugeot 307 1.4 petrol 2003 engine dianostics
hmm thinking do not disturb ----right had a look in my bible and it says CKP sensor signal ,so follow the wires from the crank sensor and along the line is a connection block connector and the dampness is causing a short of the induction signal to the computer ,right next question please triumph herald or humber ,what about a armstrong sidley ,routemaster bus?' or a BFD commer
Posted on Dec 30, 2010
Keurig won't brew, only 2 months old, not a descaling problem
If it's only 2 months old you should contact Keurig directly. They have awesome customer service and will probably replace your unit. I have read numerous postings that they will do it even if you did not register your machine.
http://www.keurig.com/contact-us
Dec 31, 2013 | Keurig Coffee Makers & Espresso Machines
Frequently it says it brewing but nothing happens...this happens about 40% of the time. This machine is only 9 months old ...could the thermostat be bad already?
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 24, 2011 | Keurig Platinum B70 Coffee Maker
Ccoffe maker won't brew. Says it is Brewing but nothing. Only about 6 months old was descaled earlier this week.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 27, 2011 | Keurig B70 Coffee Maker
My 9 month old machine only spits out water for a second
I called Keurig and they felt that it was likely a blockage at the needles, but despite cleaning them repeatedly, there was no improvement. They are sending me a replacement.
Sep 16, 2009 | Keurig Platinum B70 Coffee Maker
Heating light stays on
Nov 19, 2007 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
