Question about Poulan Garden
Poulan p3816 , when primed with 4 pushes of primer, gas comes out of exhaust . Removed plug, drained gas from cylinder let dry. Pulled cord and gas still comes out exhaust.
  • Poulan Master
  • 1,886 Answers
With the exaust in the direction of the ground not using primerbulb and sparkplug removed as you must draining the crankcase from the fuel surplus , take a stroke adhesive tape on the trottle so it get much air , and do not use primerbulb to much , its better to shoke it the first pull.
Posted on Dec 10, 2016
Chainsaw troubleshooting
It's out of gas or else the fuel pickup tube (inside the tank) is plugged or disconnected.
Aug 04, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Poulan p1500 16"/25cc trimmer wont start
If there is a good spark and good fuel getting to the plug, it may be the ignition timing is out, remove the flwheel and check the flywheel key has not sheared, if ok, pull the muffler off and take a look at the piston skirt through the open exhaust port, any signs off scuffing and it will need to come apart to assess the damage.
Oct 18, 2012 | Poulan Garden
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Turned mower on its side and changed the blade and now the pull rope is very hard to pull..its almost like the motor is locked up..I checked the shut off linkage cable,removed the spark plug, removed the...
Your piston cylinder is partially full of oil and/or gas. Take the spark plug out and pull the rope four or five times to blow everything out of the cylinder. If it's still hard to pull over with the plug out check the oil level in the crank case to see if it filled with gas while the mower was on its side. Make sure the plug is dry and clean and reinstall it. When it starts it's going to smoke a lot until it cleans out the cylinder.
Sep 15, 2010 | Poulan "Poulan" Push Mower
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Not getting gas, won't start. Fuel lines have been replaced. I think it might need a new primer pump???
check if there is a vacume line coming from bottom of cylinder on carb side and check filter in tank on end of lift pipe has it got good compresion prime bulb should lift fuel no problem unless it is drawing air
Oct 21, 2009 | Poulan Featherlite Gas Blower, with Low...
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
NOT GETTING GAS ON SEARS BLOWER
I have a craftsman 25cc blower. It is not getting fuel in the cylinder. I replaced gaskets and even the carb, no luck. When i took off the intake to replace the gasket, i pulled the start line and noticed the piston does not drop far enough to allow fuel in the cylinder.
May 07, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
57 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
