Question about Sharp XE-A106 Cash Register
On a sharp I ring up sales and get a change total then is goes a letter L and will not stop ringing up the change total
2 Suggested Answers
  • 360 Answers
SOURCE: The screen displays E 3.2 when I try to ring up a
ok press 1 and press clk key
Posted on Jul 12, 2010
Reprogramed tax after initializing Sharp ER-A330 now will not accept any sntry
I believe the ER-A330 has a Cashier # button - it should be labeled CASH #. It has to have a cashier signed on to ring a sale. Most owners forget that, because the same cashier stays signed in all the time, and nobody uses the button. If I'm right, all you have to do is this (in REG mode):
[CL] 1 [CASH #]
and start ringing your sale. The CL was to clear the error condition, if it was in one. 1 CASH # assigned Cashier #1 to the register.
The reason the register has the button is so it can track sales totals for each employee or shift. The register can be programed to stick with one cashier until another is signed on, or it can force you to sign on for every sale. At the end of the day it can print the normal Z totals by touching the CA/AT key, and touching the CASH# key gives totals for each cashier, I think.
Initializing the register cleared the cashier assignment and got you into the predicament. Touching the CASH # key twice will also clear the cashier assignment, as will resetting the Cashier totals with a Z reading. In any of those cases, just go back to REG and touch 1 CASH# again (or a different number if you want to sign on a different cashier).
Oct 23, 2012 | Sharp ER-A330 Cash Register
How do i reset my grand sales on a casio TE 2000
very simple solution with no reprogramming of the unit.
- in Z mode: make a report and read the grand total sales amount
- in RF mode make a refund of that amount
- in Z mode make a report again to check that the grand sales is zero.
Feb 24, 2011 | Casio Parts Cash Register PC Desktop
Which way do the rings need to be facing on the piston for a 2002 xr 200?
first be sure to place the rings in the cylinder and check to see there is enough ring end gap so they do not bind when they get hot. The numbers/letters face up. The gaps should be placed around the piston so they do not line up.(120 degrees for the oil rings and 120 degrees for the upper and lower scraper ring plates) Of the upper two rings the lighter color ring goes on top, it should have a rounded edge top and bottom. The second ring usually will have a bevel , scraping edge down ( again numbers/letters face up). Before installing rings be sure to roll the ring around in the ring groove to look for binding spots. If you find a tight spot , use a point file or fine cut file to clean it up. be very careful when you install your rings so do not bend or break them.
Oct 23, 2010 | 2002 Honda XR 200
Sharp ER-A330 cash register. Have to enter Cashier # every sale.
You might need a special key to program this change, but try this:
  1. Turn the key to PGM
  2. Enter 9910 . @/FOR CA/AT
If you don't get an error, you're done. Turn back to REG sign on one more time, and try two or more sales in a row.
If you get an error, this kind of programming is disabled in PGM mode. you may have to take it to a Sharp dealer who has a Service key. Your MA (Manager) key can get you to any position marked on the Mode Switch, but the SRV key goes to two more unmarked positions beyond PGM. If you have that key or find a dealer who has, turn it one notch past PGM (to 7 o'clock position).
Enter 910 . @/FOR CA/AT
[Yes, it's a different number than in PGM mode.]
If you ever want to make cashier entry compulsory again, do the same thing, except enter 100 just before touching the CA/AT button.
The reason Sharp doesn't pass SRV keys with its registers is that you can totally mess up your register if you make mistakes with this key. Don't experiment with it, or your only hope may be to wipe all machine memory to get it working again.
Sep 29, 2009 | Monroe 2020Plus Calculator
Sharp er-a330 cash register
That's a programming option -- whether you have to sign in for each sale, or can just keep going until you do a Cashier Z reading. But this on is not in your Owner Manual. Most Sharpregisters have a deeper level of programming, called SRV mode. It's not marked on your mode switch, but it's one click past PGM. You need a SRV key to access it and a Service Manual to know what's there. Sharp doesn't supply the SRV key or instructions, because it allows you to change Grand Totals and other things that would allow an employee to steal without detection.
Any servicing Sharp register dealer should have the SRV key, and this change is simple enough that they might do it for free if you bring the register to them along with these instructions and ask nicely.
Turn to SRV mode.
910 . @/FOR CA/AT
Turn to REG mode.
Sign in and try running consecutive sales or No Sales without signing in between them.
You can still change Cashier numbers between sales by signing in with a different number.
If you touch the CASH # button without putting a number in first, it will sing out you current cashier, and you'll need to sign someone in again.
If you are in X/Z mode, and you touch the CASH # button, it will print a Cashier Z reading and automatically sign out all cashiers. Sign in before your next sale.
Good luck,
Sep 02, 2008 | Monroe 2020Plus Calculator
How many rings before call goes to voive mail
I have contacted Verizon tech support for this issue. They say it depends on where you are (what towers are responding to your incoming call) and can not be changed. I told them that Cingular could entend the ring time, not number of rings. The rude customer-no-service person told me "well, you need to go to Cingular-now AT&T". We will see what type of response I get from the letter I wrote to the President of Verizon.
Apr 03, 2008 | Casio G''zOne Type S Cellular Phone
External ring type/volume buttons
there is a way to totally turn it off :/
you'd need a T6 ***** driver, and some cutting skills :D
msg me if u want to permanently disable them
Mar 11, 2008 | Motorola Mobility RAZR V3
Sharp XE-A106 Cash Register Logo
69 people viewed this question
Top Sharp Retail Supplies Experts
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
