Question about Plumbing
Mastercraft 3/4hp shallow well jet pump keeps cycling on and off for about 3 seconds at a time until up to pressure. How do I adjust? Also, pressure gauge not working. Could this be the problem
  • 258 Answers
The gauge is there to help troubleshoot problems. It does not regulate anything. It sounds like your press tank is bad. Take a tire press gauge and test the tank pressure at the schrader at the top of tank. If there is no pressure, you need a new tank.
If you do change the tank, I suggest you change the press switch and the gauge as well.
Posted on Mar 20, 2017
Testimonial: "Thanks. Basically the same thing the Canadian Tire Plumbing guy told me. However, rather than changing the tank, I have pumped up the bladder to 18psi witht he pressure off the tank. This helped but its getting bad again. There must be a slow leak in the bladder. Time to replace."
  • 104 Answers
SOURCE: Flotec Shallow Well Jet Pump won't pump water
The tank is an air tank, it works like a cushon and accumulator.
Have you reconnceted the pump? If not fill the pipe that goes to the well with water. It should not drain down, there should be a foot valve that prevents the water from running back into the well. So if the foot valve is working it should not take a lot of water to do this.
Pour water into the suction side of the pump until the pump is as full as you can get it, reconnect the pump and start it up. Yes it does need to be primed
Good luck
Posted on Mar 17, 2009
SOURCE: pump is not working, pressure gauge and pressure switch have been replaced.
the automatic pressure switch does restart the water pump when the valave is open?
Posted on Jul 08, 2009
  • 8404 Answers
SOURCE: why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
Posted on May 15, 2010
  • 3433 Answers
SOURCE: water pump keeps on running my mastercraft jet
yOU NEED A FLOAT SWItch to have the pump work unattended. I have two new switches and no use for them, Where are you?
Posted on May 26, 2010
  • 2100 Answers
SOURCE: 1/3 hp shallow well jet pump (mastercraft brand).
I don't think the power shortage had anything to do with the pump, I think it is the impeller or a gasket, or both. It is hard to say, a pump like that should **** dry and pull water right in.If you put your hand over the end of the pipe, it should make a mark like an octopus on your hand. I would take off the impeller, look for trouble, and replace 3 or 4 parts in there , you should have water. Hope this helps.
Posted on Sep 24, 2010
When H2O runs pump keeps cycling every 15 to 20 sec. H2O drops to 30psi and pump stays on until 60psi. Then a couple of seconds does again until H2O is shut off. Pump runs for around 30 seconds.
If you've got the water turned all the way on, it sounds like your setup is operating normal. If the pump where turning of and on say every 5 seconds or so I would say to check the air pressure in the water holding tank that it's at the correct pressure.
Mar 01, 2015 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground lines....
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Oct 21, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a 3/4 hp shallow well pump. It running at about ten on my pressure gauge. That means no pressure. What can I do?
If the pump turns on and off real fast, then your pressure tank is water logged. If you have
a pressure tank with a diaphram in it, you need a new tank. If it's a plain tank, then you
need to turn off the pump, drain the tank and turn it on again. All pressure tanks need
a cushion of air on top.
If the pump isn't short cycling, then try adjusting the pressure switch. There are two springs
under the cover, with adjusting nuts on them. One is for the cut in, the other is for the cut out.
I would set it so the pump turns on when the pressure drops to 30, then turns off when it hits 50.
Hope this helps ya !
Oct 31, 2010 | Flotec Corrosion Resistant Shallow Well...
Pump cycles like crazy!!
Sometimes a new tank the blatter will be kinda sealed to the sides of the tank.the amount of air in the tank s/b equal to the cut in pressure of the pressure switch.(40 lb) that would be (60 lb) cut out if you messed with the little screw on the pressure switch you have a problem.there must be the 20 psi of differance between start and stop.
May 13, 2010 | Flotec Corrosion Resistant Shallow Well...
Shallow Water Jet pump will not start
on the pressure switch are the points closed if not its not asking for water.that flat plat under the two screws with springs on them,push down on the plate that will close the points then figure out why its not closing
May 09, 2010 | Plumbing
HOW DO I ADJSUT CUT OFF/ON PRESSURE ON MY ''MASTERCRAFT JET PUMP'' [I MAY HAVE MESSED IT UP] BY TRYING TO ADJUST] CAN SOME ONE HELP ME what happens is that motor keeps on running and after while loose...
Make sure the foot valve in the well is good and the ejecter is cause I have replaced some with a pin hole in them or a rock get in foot valve and not let it hold pressure right.
Pressure Switch the big screw should be the only one you turn to adjust pressure increase or decrease if you moved the small on eyou can look at your old one to get an Idea of where it was set or get you close.
Apr 26, 2010 | Flotec Corrosion Resistant Shallow Well...
Installed a new jet pump for shallow well (gravity feed to pump) - used old pressure tank - after about 4 months pump began kicking on and off constantly when in use - troubleshooting guide suggested it...
The pressure tank must have a certain amount of air in it so pump doesn't cycle as you say. The new pressure tanks have a bladder that separates air from water and keeps the pump from cycling so much. Make sure your pressure switch on the pump is OK--ie doesn't have burned contacts!
Mar 01, 2010 | Flotec Corrosion Resistant Shallow Well...
I have a 1 hp ace pump on a 30 gallon bladder tank the pressure switch keeps clicking off and on until the switch burns up have replaced 4 times in 2 months have adjusted switch until pressure is very low...
There are tow screw adjustments on the switch. One is the high shut off and the other is 'differential'. This is the one you need to adjust. It gives the 'window' that the system needs 'between' on and off.
Aug 30, 2009 | ACE JET PUMP For shallow well
Plumbing Logo
128 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
