Question about Krups Ea9000 Barista Espresso Machine
Our Krups EA9000 just started "priming" before every drink we make. We have to empty the drip tray 4-5 times each priming cycle before the machine will pre-heat & make a drink. Anyone know why?
We have followed all of the required maintenance guidelines and replaced filters, etc. Thanks!
  • Krups Master
  • 1,305 Answers
Contact an Authorised Service Centre, they are not simple machines.
Posted on Mar 22, 2018
leethedeuce
  • 4472 Answers
SOURCE: Krups XP7240 - leaking
First off how long have you owned the unit and when did this problem develop. Once I have more information I can assist you further.
Thanks,
Lee
Posted on Oct 13, 2008
  • 279 Answers
SOURCE: Krups XP5020 manual
Try Krupsusa.com and click on "instructions" they have it there.
Posted on Sep 18, 2009
  • 39 Answers
SOURCE: Krups XP2070 coffee machine -
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Posted on Dec 29, 2009
  • 22 Answers
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Jan 31, 2010
  • 1156 Answers
SOURCE: We require service/repair manuals for
unfortunately, the service manual for your Krups coffee machines :- XP 9000 XP 7240 XP7250 FNF 1 FNF unit is not available anywhere online. The manufacturers of this Unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your Krups coffee machines :- XP 9000 XP 7240 XP7250 FNF 1 FNF via phone or e-mail and request for the service manual from them. They might give it to you or direct you to a dealer where you can get the service manual.
This is the best you can do to get the service manual you are requesting for.
Good luck.
Posted on Jun 17, 2011
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Krups EA9000 Dosing of beans.
Plug it in, turn it on and then within 3 seconds touch each of the 4 corners on the touch screen in this order Top left, Bottom right, Bottom left, Top right that should open up the settings options for you, follow your nose after that.
Jul 28, 2016 | Krups Ea9000 Barista Espresso Machine
How is it possible that everytime the machine starts with the message maintenance required,when the coffee is not even finished
Could it be that the machine needs a cleaning cycle to be run or a descale done. If neither of the above it will mean the machine has detected something about the process is outside normal parameters and should be looked at.
May 05, 2015 | Krups Ea9000 Barista Espresso Machine
Unschedules maintence
Defective electronic components.
Mar 04, 2014 | Krups Ea9000 Barista Espresso Machine
Krups error code 4
Prosz? o pomoc...mam krupsa EA9000 i wy?wietla mi code:4 , nie wiem jak si? do niego dosta? do ?rodka
Jan 15, 2014 | Krups Coffee Makers & Espresso Machines
It says driptray full, but it isn't? Any ideas?
Wevhave had ours into the shop four times for the erroneous 'coffee grounds' and drip tray' emptying. They have changed the mother board, chip in the door and even looked at the head gasket and carburettor settings but can't find the source of the problem.
What we have found latelt (it's Christmas so everything is closed for a month) is if we leave it overnight without power, 3 out of 4 times it resets itself.
It's apain if it plays up during the day but mornings brings us a good cuppa more often than not.lesson-get a deLonghi next time, this Saeco brand is more trouble than they are worth.
Nov 28, 2010 | Gaggia Titanium Espresso Machine
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups Anticalc Kit for descaling. There is no information in the box how to use this kit. How much water to add?. How long does it sit for? How many times does one boil the water after the descaling...
Cleaning the Machine
- Never wash your espresso machine accessories in the dishwasher.
After use, the water container must be emptied.
• Drip tray
This must be emptied after using the appliance by taking off the grid See figure (19)below. If several espressos are being prepared one after the other, the drip tray should be emptied from time to time (about once every 7 - 8 espressos). The presence of water is normal and does not signify a leak. If necessary, clean the drip tray and its grid with water and a little non-abrasive washing-up liquid, rinse and dry. When reassembling the machine, ensure that the plastic lining is in the right place See figure (20) below.
• The brewing head, the filter basket and the filter holder
These must be cleaned after each use. All you need to do is wipe a damp cloth over the brewing head of your appliance and to wash the other accessories in water and a little non-abrasive dishwashing liquid, rinse and dry. If the brewing head is heavily clogged up, unscrew the grid using a coin, clean it and refit it, pressing down firmly See figure (21)below.
When your espresso machine is not being used, do not leave the filter holder in the appliance to prevent wear on the gasket.
• The cup warming plate: remove this to clean it with water and a little non-abrasive dishwashing liquid, rinse and dry.
• The cappuccino accessory
For more thorough cleaning the cappuccino accessory can be dismantled from the appliance.
Descaling
Descalling (SIC) is necessary to keep your espresso machine running efficiently.
As a result descaling of your espresso machine should be done fairly frequently
with citric or tartaric acid.
• Use caution when descaling your espresso machine as the acid substance within the descaling powder may damage countertops or any other surface it comes in contact with.
However, we would advise you to use the reference solution as W F054 that is available from Krups. Descaling depends on the hardness of the water, but also on the frequency of use.
To descale, follow the following method:
• Unscrew the grid from the brewing head of the appliance and clean it See figure (21)below.
• Dissolve a packet of KRUPS descaling solution in 17 oz1510 ml of lukewarm water and pour the whole batch into the empty water container.
• Place a container under the brewing head. Run through about 1/3 of the liquid immediately, setting the selector to the position See figure (9)below.
• Stop the appliance, leaving the position See figure (9)below engaged and wait for 10 - 15 minutes to allow the descaler to take effect.
• Next, start the machine again and allow the rest of the liquid to run through.
• Then rinse with two water containers of fresh water and replace the grid on the head of the appliance (see section on “Cleaning the machine”).
The warranty does not include espresso machines that do not function, or do not function properly, because descaling has not been carried out.
May 17, 2008 | Krups Fresh Aroma 625 Coffee Maker
Krups Ea9000 Barista Espresso Machine Logo
178 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
