Question about Cub Cadet Garden
How do I remove the grass catcher from cub cadet 2500?
buffalonyman
  • 1865 Answers
SOURCE: Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Posted on Jun 16, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
  • 332 Answers
SOURCE: How to remove deck on 1045 cub cadet to remove and
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
Posted on Mar 30, 2010
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
Cub cadet blowing grass out left side of deck
If you have mowed when the grass was wet or moist you may have a build up of grass under the deck. This is the cause of that type of problem in most cases. Cleaning the build up under the deck allows the grass to flow the way its designed and will also extend the life of the blades. Hope this helps.
May 28, 2017 | Cub Cadet Garden
My cub cadet riding mower is bogging down when grass gets a little thick
Inspect the under side of the deck for grass build up. You need to clean it about twice a year if you are mowing damp grass.
May 06, 2017 | Cub Cadet Garden
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
54" Cub Cadet deck leaves strip of grass since I replaced the spindal
all three blades have to be lined up the same way when you put the belt back on.
Sep 09, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
How do you remove the blades for sharpening on a CUB CADET 1042?
when i do mine i drop the deck off then remove the blades and clean the old grass off at the same time it keeps it from rotting out
Jul 01, 2012 | Cub Cadet Garden
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
44 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
