Question about Radio Shack Pro-82 Scanner
Radio Scanner no good???
I'm having trouble, I just bought a brand new rs pro-82, i turn it on and it powers on, i turn the squelch nob to the right but the static never goes away like it's suppose to??? Also I am not able to receive anything, not even the weather??? Help
  • Anonymous Apr 17, 2008
    need help programing
  • Anonymous Jun 12, 2008
    my pro-82 scanner wont recieve anything why
Scanner codes
Posted on Mar 19, 2008
Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
Sep 21, 2011 | Radio Shack Pro-82 Scanner
My Radio Shack Pro-82 Scanner is not working at all.i turned it on and it wont even scan. i cant even hear the squelch. and the only time it picks up something is when its on the air setting it picks up...
Ok I have had the same problem with the Pro 82 and the biggest problems I've found for it not to scan is Corrosion of the terminals not only outside but inside. Even on the keypad and pcb board. SOLUTION: Just take it all apart with a small philips pecision screwdriver and with a dry toothbrush scrape all the corrosion off the board. This always solves my problem and it should yours. Even if theres no corrosion visible on the terminals be assured there is still some inside keping this from functioning correctly. Shotgun420
Jul 30, 2011 | Radio Shack Pro-82 Scanner
Last night was working fine - as it was on I noticed that the scanner was just stuck on one channel - I hit scan ( I have several channels programmed) It wouldnt scan. Then when I turned the squelch...
Hopefully Resetting or Initializing the scanner will clear the problem and get it working again for you. Instructions for these procedures are on page 38 and 39 of the scanner operating manual. If you don't have the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
May 24, 2011 | Radio Shack Pro-82 Scanner
My scanner will not scan
You need at least 2 or more frequencies programmed, and
adjust the squelch knob until there is no more static, then press the scan button.
Here's a manual
Feb 09, 2010 | Radio Shack Pro-82 Scanner
Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Nov 02, 2009 | Radio Shack Pro-82 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Loss user manual for Pro-82 Scanner Reciver.
Hi - You can download the manual from the link below:
Radio Shack Pro-82
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 09, 2008 | Radio Shack Pro-82 Scanner
Pro-82 scanner
go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
Jun 15, 2008 | Radio Shack Pro-82 Scanner
Radio shack pro 2067 suddenly not receiving
I had the same problem. I realize this is a little late but I just came across this site. I opend it up and the alum wire connecting the BNC to the mother board was cracked. Iput a dab of solder on it and it was good as new.
Wish I would have found this b4 u tossed it.
Bryan MC
bryanmc@windstream.net
Jan 25, 2008 | Radio Communications
Radio Shack Pro-82 Scanner Logo
133 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
