How to you cut 2 lines with the top word centered overhead the bottom word
  • kakima Dec 10, 2016
    Hi Cindy Whiteman, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Using what program?
  • 1153 Answers
SOURCE: mx-42vm10
Sounds like convergence are off. Go to menu and find tv convergence and reset. This deals with red, blue, and green.
Posted on Aug 22, 2007
jerryg50
  • 1667 Answers
SOURCE: Need to center the picture
This is a defect in the vertical scan amplifier. It is not an adjustment. Most of the time there are a number of capacitors in the vertical deflection amplifier that can cause this type of fault. Sometimes the output drive IC can cause this fault, but more rarely.
An experienced service tech can locate the defective parts and replace them. The average time involved is about 1 to 1.5 hours.
Jerry G.
Posted on Jun 02, 2008
ramon49
  • 111 Answers
SOURCE: The screen colapsed into a thin line running from the top center
The deflection circuit is most likley bad. You need a service center to repair . If you can TEST THE BIG FAT TRANSISTORS AND CHANGE OUT IF BAD, THEN YOU CAN FIX IT. They are usually on a big metal finned heatsink ...
Posted on Mar 07, 2009
  • 8 Answers
SOURCE: the screen has atleast 2 inches white/black strips/lines running right in the center of the screen from top to bottom
sounds like a bad lcd converter...
Posted on Jun 02, 2009
flipbooks
  • 177 Answers
SOURCE: 2-3 inch swath of green from top to bottom of screen, in center
Might be a problem with your memory,your video driver,or the screens inverter board.
If you have more than 1 bank of memory,try removing one bank at a time and see if this corrects the problem. If so ,replace the bank that was removed when your screen works properly.
Also ,try updating the driver through the "Windows Update" service. If neither of those works, you may have a faulty inverter board.
Posted on Jul 22, 2009
How to line the camshaft gears on 2004 dodge stratus to replace timming belt 2.4 duel overhead motor
Hi Darryl, I'm AL the owner of Big As Auto Repair in St Charles Mo
Boy, have I done a few of these, in fact about 400 through the years.
FIRST: Bring your number one piston to top dead center, if you haven't already done so. NOTE: When you have lined everything up you will notice that the crankshaft alignment mark is just a little off, this is OK. The Camshaft marks on the sprockets or cut-out across the sprocket, there will be 2 cut-outs on each sprocket, you will need to line this cut-outs all the way across both sprockets with a straight edge, I always used a ruler. If you need a picture I can send one through your email, go to my website and give me your email through contact us. click here: Auto Repair
Mar 22, 2015 | 2004 Dodge Stratus
Cutting a new counter top for a sink
If you are installing a basic stainless steel sink into a laminate over particle board counter top-
Find the center of the sink along the legnth of the counter and mark the counter. Measure the sink from the top. Lay out the edges on the counter. Place the sink upside down on the counter and align with your marks. Trace around the sink in pencil. Subtract the distance to the flange where the clips slide in. Draw a new line inside the first one. This is your cut line. Check that when you make the cut that you will not hit the face frame of the cabinet. Move the sink back if needed and make new marks. Some cabinets are a tight fit. Cut the hole for the sink with a jigsaw. Start with the back line first. You may find on a counter with a back splash the jigsaw will not fit. Drill an 1/8" hole to mark the underside and cut from the bottom of the counter. Use a 1" spade bit to drill starter holes at the corners keeping away from the line you traced when the sink was upside down. Stay away from that line or you will have a hole the sink won't cover. Cut the front line. Drill a hole in the center of the counter you can put your finger in to catch the piece when it falls. Now cut the side lines while supporting the counter that is being removed. Discard the slug you removed.
Test fit the sink and remove any extra until the sink just drops in. Remove the sink and set it aside. You need at least 2 sink clips on each side of the sink but use 3 if you can get to them. Determine the location you want the clips at. Use the 3/4" spade bit to drill uot a pocket for the clips to go into. They will normally hit the bottom layer of particle board in the front and back. Center the bit horizontally 3/8" up from the underside of the counter. Drill your holes 1" deep. This is where the spring clip on your sink bolts will grab. You can test that the clips will fit then put a small beed of clear siliconized acrilic latex calk around the edge of the sink and install. Wipe up any extra squeeze out with a wet rag and then tighten the bolts and clean up again.
Now you are ready to install the plumbing. If you are using a new garbage disposer with the dish washer draining into it there is a small plastic disc you have to knock out before the dish washer can drain into the disposal. That plug is there to seal the disposer if you don't have a dish washer.
Get more help if you do not understand all the instructions. If you are pretty handy with mechanical things you should be able to get this done. If you have a different kind of sink please specify that and get more help.
Mar 19, 2014 | Tools & Hardware - Others
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Where is tdc on my 2001 dodge ram 1500
top dead center
ok look at your damper pulley its the pulley at the bottom of the motor
the damper pulley has a line cut in it
line the mark up with the degree marks
you want to put it on the zero mark
once you have done this you are on top dead center
also number one cylinder must be on a compression stroke
pull spark plug number one turn the motor over with your finger
over the hole when you feel compression that's when you line
up the marks.
hope this helps you
good luck
bob
May 06, 2011 | 2001 Dodge Ram 1500 Truck 2WD
Daewoo lanos 1.5l timing belt marks
Answer
If this is a single overhead cam, possibly A15SMS (engine type):
If you have everything stripped down and can see the crank shaft gear, you will notice an arrow stamped into one of the gear teeth.
this arrow must point towards the bottom, you will notice a mark (notch) cut into the housing, line the arrow on the gear with this notch.
remove the four 10mm bolts that secure the top cover of the timing belt, gently open the cover (not removing it) to see the Cam Gear. You will not be able to remove the cover because of the design.
The Cam Gear should have a line stamped into one of its teeth, this should be pointing up and towards the top. On the inner cover you will notice a notch in the casing, line both up together if it is not already.
You can check the following if unsure:
Remove # 1 spark plug (nearest the Cam Belt) and place a long screwdriver in the hole carefully to feel the piston is at the top, #2 and 3 will be down and the last one #4 at the distributor end will also be up.
Remove the rocker cover and you should see the Cam loabes on #1 piston free, (no pressure on the cam shaft) meaning the valves are closed.
tim
Dec 06, 2010 | 2001 Daewoo Lanos
My hitachi 51f59 picture shakes about every 30 seconds and then repeats.there are also 2 horizontal lines that go from the bottom of the screen to the top and repeats.
It sounds like feedback from somewhere else other than your tv like a overhead light or a blinder suggest using a surge suppressor to help block spikes of this sort.
Jun 27, 2010 | Hitachi 51F59 51" HDTV Projection...
How to build a wooden pyramid frame for school children, 2metres on each length of base.
cut 4 pieces of 2x2 to1.5 inches short of 2 metres. lay them out end to end to form a two metre box. it can only work one way. then take string from corner to corner to find the center, making a crosshair. then stand a level rod at the centre to the desired height and fasten equal length lines from each corner to the peak. using a compound mitre saw, place an angle finder at the bottom and top corners to give you the angle to cut your piece with the saw set at 45 degrees, to give you your compound miter for the top. just set the saw blade to line up with the angle finder to get the bottom cut. the length of your "tight" string line frome corner to peak is your length of "hip" piece
Mar 10, 2010 | RTO M-D Building Products Carpentry &...
How to set the timing on a 98 chevy truck 350
PUT THE #1 CYL ON TOP DEAD CENTER COMPRESSION STROKE (HAVE I FRIEND BUMP THE MOTOR OVER BUMP IS THE KEY IUNTIL YOU FEEL THE COMPRESSION IN THE CYL BLOW YOUR FINGER OFF THE HOLE THEN LOOK AT THE BOTTOM CENTER PULLY IT SOULD HAVE A LINE CUT INTO TO FIND IT THEN LOOK ON THE TIMING CHAIN COVER (RIGHT BY BOTTOM CENTER PULLY) THE SHOULD BE A TAB STICKING OUT OF IT AT SHOULD BE MARKED 0-2-4-6-.... PUT THE LINE OFF THE PULLY ON THE 0 ON THE TAB. THAT IS TOP DEAD CENTER. NOW GO TO THE DIST. AND PUT THE ROTOR IN THE CENTER OF THE NUMBER ONE CYL POST OF THE DIST CAP. START VECH.
Oct 01, 2009 | 1998 Chevrolet K1500
2007 Chevy Uplander Rear Overhead A/C Vents Won't Work
Have you checked the Aux switch near the bottom of the center control console.
There should be a knob with: Aux, Off, 1, 2, 3. This is the switch for the rear AC blower.
If the driver wants to control the rear AC, use the 1, 2, 3 settings.
If you put it on Aux, Than the rear AC is controlled by the passenger in the back seat using the extra controls located on the Overhead DVD player. (The front AC must be on the rear to work)
Jul 09, 2009 | 2006 Chevrolet Uplander
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
