Trying to hook up magnVOX 15'' HD TV MONITOR and not sure abbout ports on back of pc
  • 31 Answers
Depending on the model of pc and what graphics card you may have. But generally, just match the color coded port to the color coded cable. VGA(blu), HDVI(long and white), Composite (white,yellow, red). If you are using VGA, or HDVI, you will need and additional cable to connect the audio from the pc to the TV. It has two male ends that look like headphone plugs that you plug into PC's green or blue audio ports. If you have a 7.1 audio card, you may want to used home entertainment system for audio but not being connected to the TV means you cannot record TV unless you have a TV tuner built in to PC.
Posted on Jul 20, 2009
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the...
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 27, 2010 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
May 31, 2010 | Toshiba Computers & Internet
Trying to connect PC to Philips LCD HDTV
While the tv is on the right input, and the computer is running, try unhooking the cable and hooking it back in. That's the only way I can get my Philips to detect the HDMI signal from my pc. I haven't found a fix for it though.
Jan 29, 2008 | Philips 37PF9996 37 in. HD-Ready LCD...
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
