How long should it take foe water to start on the quick wash cycle
    Top Expert:
  • Washing Mach... Master
  • 8,204 Answers
It should tell you in your manual,,all washing machine dont run the same..
Posted on Dec 10, 2016
Why does my whirlpool model WTW57ESVW1 starts to rinse toward the end of the spin cycle?
The rinse is supposed to start during the's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Sep 06, 2014 | Washing Machines
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
My dishwasher isn't working, it fills with water then doesn't do anything. The water doesn't seem to be hot. Does it need to be heated before starting the washing action?
Try running your sink water till it's hot and then running the wash cycle. Not all washes have a quick heat element.
Dec 23, 2010 | Dishwashers
The washing machine starts ok and fills with water. However, it quickly begins to intermittently cut in and out whilst filling with water. It does this for a while before stopping completely. I've tried...
you did not mention the type of machine but for top loader the most probable cause of your issue is the door /lid switch that is in need of adjustment as most top loaders will fill with the lid open but cycle cant start or continue when the wash thinks the door is open this is a safety feature
Aug 14, 2010 | Washing Machines
When our new LG washer starts its cycle, the water seems to do quick bursts into the washer making the pipes make a bad noise. Any advice?
The quick burst of water is normal for the LG washing machines, its the way the water valves work. The noise you hear, sounds like the water lines jerking, and hitting against the wall, or the cabinet itself. You may need to get some tape, and tape the lines to the unit itself.
Mar 22, 2010 | LG Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Conditioner is not used in the wash cycle
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
Dec 12, 2006 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
