Question about Cadco Ovens
I keep getting the error code A03 on my cadco xaft135 convection oven
  • 109 Answers
SOURCE: Cadco XAF 115 fan not working
make sure you have selected convect bake, otherwise remove oven from wall to acces the back and test voltage at the fan, most likely the fan is bad, if you use conv. bake alot
Posted on Mar 30, 2008
localwonder
  • 6784 Answers
SOURCE: f9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Posted on Jul 30, 2009
localwonder
  • 6784 Answers
SOURCE: Just received a used GE profile electric
HI. this "F-1" code Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Posted on Aug 08, 2009
  • 193 Answers
SOURCE: I need to replace the
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
Daniel S
  • 4323 Answers
SOURCE: CADCO UNOX CONVECTION BAKE XAF130 I
Hi
This indicates a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 21, 2011
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
Need to glue outer cold glass door to the door frame.. in cadco convection oven
not sure which to use but id go to a window auto glass shop and inquire
Dec 12, 2012 | Cadco Ovens
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
F9 error code while using the convection baking function
Jul 30, 2009 | GE Ovens
Mar 29, 2008 | Ovens
Ovens Logo
105 people viewed this question
Top Cadco Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Cadco Oven Expert? Answer questions, earn points and help others
