What is the VA rating of a suburban P-40 propane furnace (120 V) transformer?
  • Heating & Co... Master
  • 1,658 Answers
Should be 40. Look on the transformer
Posted on Dec 10, 2016
Amana furnace. How do I replace a 4-wire transformer with a 6-wire?
The new transformer should have a description on the side or top. Like: Com, Color, Volt. For example, say you have `120 volts, com-white, black wire - 120 Volts. Make sure you carefully read which wires to use or have a tech come out.
Nov 12, 2015 | Heating & Cooling
It's 110v model and I want to run it on 230v. If I use a transformer what rating would you reccomend. If I try to convert to 230v what would I need to do. Also can you point me to an operations manual....
You need the total amperes of the refrigerator and multiply by the refrigerator volts to get voltamps, then choose a transformer that is rated at least 120% of the voltamps of the refrigerator. e.g. refrigerator runs at 120 volts and 7.5 amperes, 120 x 7.5 is 900, then 120% of 900 is 1080. A transformer of at least 1080 VA (volt amps) that is 220-240 volts primary and 120 volts secondary. 1080 volt amps is same as 1.08kva (kilo volt amps).
Mar 15, 2015 | Refrigerators
I have a Crosley CR66-PA. It's 120 volts and I
It might have blown the fuse if you are lucky. Otherwise it's likely the transformer failed.
Jun 11, 2011 | Crosley Audio Players & Recorders
Hello, make sure that it is the correct VA rating for the furnace. if it too small it will keep blowing. Also, i would check the wiring at the control board make sure it is not touching any other wires there.
Feb 23, 2011 | Heating & Cooling
I would like to direct wire the humidifier to the furnace so evey time the furnace goes on so does the humidifier no humidistat I have a Heil NUGM100EHA1
connect a 24 volt,20 va transformer to the wires supplying power to the indoor blower motor of furnace, connect the primary wires to heat speed of furnace motor, then connect the two low voltage wires to the secondary side of transformer, good luck.
Feb 15, 2010 | Aprilaire 700 Humidifier
We replaced our thermastat with a new one and it would notwork. replaced with the old one that had worked and now it does not work. is there a reset
Common problem with changing a tst. You blew the fuse in the furnace or Air Handler or you burnt up the transformer in the furnace or Air Handler. Hopefully you just blew a fuse. A 5 amp automotive fuse will fir back in the holder. Most all companies use a auto fuse 3 to 5 amp. Some have abreaker on the transformer. If you burnt out transformer you have yo replace it. Not hard to do Most of the time they 40 VA transformers. Go to HVAC supply house and buy one about 15.00
Dec 05, 2009 | Refrigerators
Master cool controller failed
generally this is a 115/24 40 va transformer, as long at the VA rating and mount is the same you can source a universal.
Jul 18, 2009 | Mastercool 67680 Evaporative Cooler Air...
Transformer VA size? 208 pri 120 scc
Look at the 'amps' rating. Multiply the (volts x amps=VA )
Jul 07, 2009 | Hatco S 36 Imperial Electric Booster Water...
Coleman Propane Furnace Good pilot light but feed/ignite main burner
If you have a volt ohm meter take the two leads off the gas valve and ohm out the connection should have resistance for the coil. You said you have 12 volts from the thermostat white and red in the heating mode you should have minimum 26 volts. If you want to check the transformer should have 28 volts. Almost sounding like the transformer is getting weak. You can get parts for a 20 year old unit at any HVAC parts house. Try Washer Specialties here in Wichita Kansas they are on the web. Lowes even carries Transformers. Has to be rated 120 volt primary side secondary side 24 volts and 40 VAC.
Oct 27, 2008 | Coleman Propane Forced Air Heater...
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
