Question about Garden
455 56CC RANCHER NO COMPRESSION - Garden
    Top Expert:
  • Garden Master
  • 8,211 Answers
Trying to find the correct compression for a Husqvarna 455 Rancher chainsaw?
you wont... as per husky anything under 110 would be suspicious. I have seen those saws with the lower piston ring gummed up from a rich fuel mixture.
Nov 29, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Honda rancher
If the saw was run to lean on fuel it would not be properly lubricated and cause scoring of the cylinder or burnt a hole in the piston. If this saw has a compression release valve it could be stuck open.
May 26, 2013 | Garden
Huskavarna 455 rancher with pplug keeps popping out
This is the de compression button, it should be pushed in every time you start the saw, it makes it easier for you to start the saw and reduces the stress and wear on the starter components, it will automatically pop out when the saw starts.
Dec 08, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Compression ratio for husqvarna 455 rancher chainsaw
be careful check the compression on that engine it has a compression release valve on the side of the cylinder the release builds up with carbon and it sticks dropping the compression
Aug 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Husqvarna 455 Rancher - about 1 month old. Worked perfect one day. Would not start the next. Feels like there is no compression. Second 455 with this problem.
There is only two reasons for low compression, either the piston ring has gummed in, or the piston has seized, remove the muffler and check out the condition of the piston skirt through the open exhaust port, any signs of scuffing and the piston has seized, it will then need to come apart to see how much damage has occured. Saws today are set up very lean on the mixture to get the best emmissions not the best running, they realy need to be using the very best two stroke oil.
Sep 09, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
What will make my 2001 honda rancher 350 blow oil out of the engine vent tube?
Compression, getting past the piston rings, is what actually forces the oil out. But fuel is in the compression blowby right along with air as the compression goes into the gearbox. The fuel mixes with the gearbox oil and actually increases the amount of fluid in the gearbox. Too much oil/gas in the gearbox puts the "oil" level much closer to the vent and promotes the oil leak. The proper fix is to do a top end job costing around $750 at the shop. The ******* way is to change the oil more frequently and maintain the proper oil level between oil changes. The cost of oil should be a bit less than the cost of a top end job..
Sep 05, 2011 | 2009 Honda FourTrax Rancher 4x4
Will not crank,low compression husqvarna 455 rancher
How you cnow its low pressure? check spark, air filter, and any air leak from between cilinder and carburator.
Oct 14, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher . it has low compression and no fuel to plug . wont start but piston and rings are fine .Help
it could be the small gasket between the head and carb. they are also bad about the fuel line coming out of the tank gettin rubbed and making a small hole or pinched.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
