Question about Admiral Washing Machines
Admiral Ultimal AL46000 wasn't spinning and when the back was removed the motor's rubber seal was twisted and was removed.Now what to do?
  • 60 Answers
SOURCE: rubber seal removal
There is a spring at the bottom center of the door gasket. Stretch that out and a wire will come off from around the gasket you can then pull the gasket off and reach in. Be sure you get the gasket back on all the way and the wire right or it will leak. Good luck.
Posted on Feb 16, 2008
  • 1554 Answers
SOURCE: Front Load Washer Seal
you will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Posted on Mar 31, 2008
  • 478 Answers
SOURCE: Rubber seal on Frigidaire twisted during wash.
The only way to realign this is toremove the sping under the lip at the door portion of the seal,this is a tough one youll need a third and forth hand.
Posted on Mar 15, 2009
  • 1474 Answers
SOURCE: Removal of rubber seal
I take off the top cover unplug machine 1st ..Safety...Then take offretaining ring on inner drum /also ring on outer drum remove boot seal..Check utube video, explains in good detail...
Posted on Oct 07, 2009
SOURCE: knocking sound, violent spin cycle led to not
my problem to just 3 days ago from yours! bearings are out, $600 getting a new one.
Posted on Jan 22, 2010
Clothes got twisted on front rubber piece put it back together and now the washer does not spin
Did the rubber tare when it got twisted? If not did you remove the rubber below and reinstall it. If not then it may of slipped and could be causing a bind in the drum.
Apr 11, 2014 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer won't agitate or spin
i believe this is what we call a direct drive system 2 things it could be is the drive coupler located under unit between the transmission and motor .it is a plastic piece with 3 prongs on each side and a black rubber bushing that goes in between each side to connect is somewhat like a shear pin on a tractor it is designed to break when to much pressure... before you check this make sure the unit is making some sort of noise when it is suppose to agitate or should hear the motor running just won't spin the tub... if you are not hearing anything then i would suspect you have a bad lid switch on the unit... the lid switch is like a safety switch while running if the lid is raised the unit will stop power supply to motor can check the lid switch byby passing it temporarily and see if it works .... one of the 2 may be your issue.... good luck to you
Feb 11, 2011 | Admiral 32 cu. ft. Washer
Pool sweep pump stuck and will not turn.Binding on impeller to rubber seal.How to disassemble remove impeller and seal.
Sounds like maybe your motor bearing are going bad, or have already seized up. When you say "rubber seal" are you referring to the rubber portion of the shaft seal? Either way, to remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. If the bearings are seized up then you'll have to replace the motor, or have it rebuilt.
Sep 18, 2010 | Pentair Letro Booster Pump IMPELLER LA02L
Admiral machine won;t drain water
If the machine is spinning then the problem will be a blocked pump, this is driven off the motor when spinning so is a simple impeller in a casing, remove the pump and check for debris inside.
Dec 06, 2009 | Admiral AW22 Top Load Washer
Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Nov 25, 2009 | Admiral AW22 Top Load Washer
Blower motor
I just recently had to do this myself, and thankfully its not too difficult. for ease of access start by removing the plastic cover that protects the fuses and relays in the engine compartment. next, using a 1/2" socket or wrench remove the two nuts that secure what seems to be a lift brace on the back of the engine.
with those two items out of the way diconnect the power from the blower motor. use a 9/32" wrench or socket to remove the 5 or 6 bolts that secure the motor to the firewall. with the bolts removed you may need to gently pry the rubber seal off of the firewall in order to remove the motor.
with the motor loose you should be able to spin and jimmy it around the tube that the tranmission dip stick resides in and remove it from the car. remove the rubber seal (and blower blades if necessary) from the old motor then follow the directions in reverse to install the new one.
Dec 28, 2008 | 1991 Pontiac Bonneville
You need to check if there is power to the motor. If so the motor is defective.If not, the timer may be the problem. There should be a wiring diagram on the back of the unit. Using a voltmeter, trace the power.
Dec 17, 2008 | Admiral AW22 Top Load Washer
Lid switch for admiral washing machine (13 years old)
From description it looks more like you have to replace the lid switch, if you have to push it down, then the contact inside is broken.
You find replacements here, just insert the model number.
Sep 14, 2008 | Washing Machines
Agitator won't move in wash or spin cycle on my admiral washer
The rubber that connected to motor is loose already,needs to change that why cannot spin...
Jun 19, 2008 | Washing Machines
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
