When scanning using the paper size set to the autodetection setting, any sheet of 11x17 or 8.5 x 11 (landscape) gets cut off. We have a DC-5010c scanner. Running the latest driver, firmware and capture perfect. If we set the page size to 11x17, it will scan the entire page. Any help would be greatly appreciated.
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
S. Mohan, Chennai, India
I am having fujitsu twain scanner and it is giving me an error as communication failed when am...
(More)
I am having fujitsu twain scanner and it is giving me an error as communication failed when am trying to scan doc.
optex digiscan1 35mm slide & negative scanner. running xp prof. from arcsoft photoimpression...
(More)
OPTEX DIGISCAN1 35mm slide & negative scanner. Running XP Prof. From Arcsoft PhotoImpression 6 can acquire image. Cannot save - always fails on TWAIN - not responding (UTwainExe.exe) - consumes 58% CPU when TWAIN invoked Solution ?
canon dr-120c scanner problem. was using and it just shut off, lost power. tried everything. please...
(More)
canon dr-120c scanner problem. was using and it just shut off, lost power. tried everything. please help if you can. canon can not....
I'm trying to scan a test chart into a DR-5010 scanner. It's a little wider than a regular page. I'm...
(More)
I'm trying to scan a test chart into a DR-5010 scanner. It's a little wider than a regular page. I'm using paperport 11. I changed the width and legnth using the area tab, but it still cuts off about a fourth of the chart after it scans and goes on to paperport. It shows the whole chart when I preview it, but the output isn't the same as the preview. Any suggestions?
