Question about Kitchen Ranges
I am trying to use guick bake feature on our new frgidaire gas oven. I turn quick feature on. However, I thought the fan inside is suppose to come on. I am wondering if I am missing a step?
Tech007
  • 63 Answers
SOURCE: Oven "bake" doesn't work...
sounds like the bake glow bar needs to be replaced it is under the bottom cover inside the oven good luck
Posted on Aug 29, 2007
catriver
  • 878 Answers
SOURCE: Kemore Gas oven - trouble igniting
Hi Deeg, there was a service flash regarding this problem. The bake burner and bake igniter have been modified to assure consistent oven ignition and performance. The number of ports on the burner have increased located at the electrode tip. The electrode shield has also been modified. This repair should be covered under warranty. The kit part number is 8190618 for your information. If your serial number ranges from RK01 through RR11, this is your problem. I would call Sears and request service. Catriver.
Posted on Sep 12, 2007
SOURCE: oven is slow to start
Dear Friend,
I had the same problem and the first step you should take is to replace the bake ignitor, you most likely to have a weak ignitor. If this doesn´t solve your problem, than your gas valve is failing. Despite the broiler is ok, the gas valve has independent channels for bake and broiler, so it´s possible for one to fail and the other is good. But i believe that changing nthe ignitor will solve it.
Zanes
Posted on Oct 17, 2007
Master_Tech
  • 770 Answers
SOURCE: Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
  • 142 Answers
SOURCE: Oven blown up??? Is it a simple fuse or is it a big job???
sound like fuction switch has blown apart quite common and the noise is prob coming from cooling fan and not the main one inside.
Posted on Sep 14, 2009
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
Large oven in dacor dual oven range broiler comes on when i select bake
on bake both bake and broil will come on the broil shuts down around 260 deg
this is normal its done to shorten preheat time
Jun 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Baking on two racks - whenever I try to bake cookies on top and bottom racks, the lower tray does not bake anywhere NEAR as quickly....should I be able to bake evenly on up and down racks?
Two racks never bake as evenly as one unless you use the fan inside the oven if you have one...The fan will also shorten the baking times...
The other thing that I would check is to make sure that the lower element in your oven is not blown and you are heating with the top element only...
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Sep 14, 2009 | DeLonghi Ovens
Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Convection fan doesn't turn on
Found this site cuz I had the same problem- as your purchase was 4 years ago- not sure that I'll help you... But help others who are stumped... I pushed the QuickBake button to preheat then to turn the fan on I pressed it again... ( actually a couple times messing with it...) Once it gave me a " double beep" and sometimes just a single beep but none the less, the fan turned ON!!! Good luck!
Nov 18, 2008 | Frigidaire Gallery 30" Self-Cleaning...
Dacor oven
I believe it is supposed to be. Prebake, including the convection fan, will happen until the oven reaches the set temperature.
Dec 11, 2007 | Dacor Preference PGR30 Gas Kitchen Range
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Aug 29, 2007 | KitchenAid KGST300 Gas Kitchen Range
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
