Question about Cobra Radio Communications
I HAVE A COBRA 19XS RECEIVE WELL, WHEN KEYING MIC IT SHOWS 3.5 WATTS WHEN TRANSMITTING NO AUDIO, MIC IS GOOD, COULD IT BE THE KIA7217AP BAD OR A TRANSISTOR BAD.
  • larry McCormick
    larry McCormick Dec 10, 2016
    NO AUDIO OUT OF PA EITHER, WHEN SWITCHED IN PA.
    Genius:
  • Cobra Master
  • 1,795 Answers
It is possible that the audio amp is bad but not necessarily. It could be a combination of the amp and the final but it could also be a resistor not allowing power to either. Check the resistor at the final and also the ones in the audio circuit .
Posted on Feb 02, 2017
  • Cobra Master
  • 16,658 Answers
CB warning antenna on a cobra 29 lx camo
You may have blown out the output transistor in the CB. Can you still calibrate the swr meter? The K 30 isn't really a very good antenna. The Lil Will isn't either. I'd try a K-40 or a better model Wilson antenna.
May 08, 2016 | Cobra Radio Communications
Cb is Keying Down instead of keying up when trying to talk
if you are transmitting fine Don't worry about the meter. Get an external SWR meter, they are better anyway.
Also, make sure the the switch next to the meter is all the way up on s/rf setting. thats for signal power and receive strength.
Aug 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cb problem have a cobra 19dx iv with a 2ft magnet mount cobra antenna swr is good, receive is good, but muffled output
Hi and welcome to FixYa,
Which output is muffled, transmit (modulation audio) or receive audio?
If you are referring to the receive audio, initially, have you tried an external speaker? If it works good, then it would be an internal speaker problem; if not then others to check would be:
  • IC1 - KIA7217AP audio IC;
  • CM 10 & 15 - audio output capacitors 470uF / 16V.
if it were transmit / modulation audio, try replacing the mic.
Please postback updates.
Good luck and thank you for asking FixYa.
Aug 01, 2009 | Cobra Radio Communications
Tunring up a cobra 150 gtl/dx
Um... What?? This is hooked to a switch? CB radio by FCC regulations is only supposed to have a max of 4 watts total output. If you can flip it to 7 watts dead key, you are doing really good. It won't do much more then that. It sounds like its set up to run on a linear amplifier, which cannot have more then 3 watts dead key transmitting into it.
Dead key, and modulation are different. You may have a meter that only reads dead key, and won't see the modulation. This radio is probably swinging close to 15-20 watts. you need a meter that can read PEP, Peak envelope power. Cheap meters only read AVG, or average power, witch will only show your dead key.
7 watts dead key is really good for that radio.especially since stock only has 4 watts. you cannot get any higher then that without changing finals.
at 3 watt dead key, or 7 watt dead key, your modulation wattage is still swinging much higher.
Also, you will get more swing with a lower dead key any way, which is better if you want it to be loud.
Leave it alone. its probably set just right.
May 12, 2009 | Cobra 150 GTL DX Base CB Radio
Where does the pin on a mic go to on a cobra 29 ltd
1/ shield 2/ audio (usually white,it's the wire the shield is wrapped around) 3/ red 4/ black if the radio transmits without keying the mic. switch # 3 and # 4.Good Luck
Apr 25, 2009 | Cobra 29 LTD CB Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Microphone
If the radio receives OK and the TX red LED will not lit up when keying the mic, then it is a mic or mic cord or mic connector problem (or pin configuration). Internally to the mic, there is a switch for keying the PTT. This should be check down to the coiled cord to the connector.
If all of the above checks OK, then you would need to check the TX/RX regulator/switching circuitry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
CB transmission
Hello 64driver,
Make sure the radio is grounded properly and that the SWR is around 1.2:1, 1.3:1 is good but try to get it to 1.2:1. Also take a power output reading while keying the mic. To do this with your power meter put it in-line with the CB and your antenna and key the mic you should get about 4 to 5 watts PEP. If this is the case your unit is putting out the proper power level, if not have the power amplifier checked by a qualified repair shop.
I hope this helps
Shuttle83
May 13, 2008 | Cobra 19 DX IV CB Radio
Cobra 18 WX ST Wont Transmit
Hi rem_fishing ,
Would seem that your Audio IC is busted. No receive audio, no TX audio. This would be IC2, KIA7217AP
Mar 29, 2008 | Radio Communications
Cb radio
i have a president hr2510 when you finish keying the mic.say am,usb,lsb the receive takes a 2 seconds to come back on any ideas out there....
Aug 08, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
656 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
