Question about Whirlpool Kitchen Ranges
Whirlpool accubake RF367lxsq oven controls don't work, can't turn anything on except top burners
My oven has been throwing codes for a year now. We were unplugging and replugging and that fixed the problem. Now, the electronic panel doesn't work at all...can't adjust the clock, fan won't come on, temp stays at 350, start, off, on, clean...none of it will respond.
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
I have whirlpool accubake model wle 3430 almost 10 years old and have a code E1 F1 and oven is not working ! 1 e
The F1-E1 error code means the control board has detected a problem within the control itself and the control board needs to be replaced
When ordering the control please note it may also be called the,CLOCK,EOC or Electronic Oven Control in addation to the control board..any of those names it will be the same part.
GENE
Sep 04, 2011 | Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
Whirlpool Accubake is displaying a PF code...should I buy it?
It appears your clock assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 04, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
