SOURCE: COD MAN TGA EDC
EDC Electronic deisel control
03050 After run test, zero quantity
03 implausible
SOURCE: I have problem with my MAN truck TGA 33.400 It
EDC 03779-10 = Fuel pressure too low in the common rail.
Start by checking the fuel filters and the likes for deposits or leaks. Then take it to a repair shop and have them check the fuel pump itself. Finally they will have to dismantle the common rail and the injectors to check for abnormal wear.
This is a big job and if the pump will have to be replaced, very expensive.
SOURCE: my man tga tuck show this on dashboard edc 03779-10 what is the meaning
The following link provides the brief explanation of the error codes. The EDC code reported is likely related to the common rail fuel delivery system. It will likely take specialized equipment to diagnose the problem properly only available at a service center.
Hope this helps?
http://www.techtransa.lt/MAN_klaidu_kodai.pdf
SOURCE: Vahichal power down man tga 33-410 Edc 03082-00
Skin is basically three sorts, dry skin, greasy skin and mixed skin. For skin types that were various various aesthetic products have decided carefully in order to give skin cells with proper nutrition. You-can't utilize all cosmetics about it in case your skin is not insensitive. You must take the skin care expert's assistance before choosing any aesthetic merchandise to your skin. Your skin layer is nourished by all cosmetic products . Sunscreen products form a level around the skin to safeguard you from your dangerous aftereffects of rays of the sun. Healthy products get further into skin tissues to nurture the skin from there.
http://nuvieskincareserum.com/luxia-no-7/
1.EDC:00959-01
>seconds-Action-Tachometer has lost memory and is not aligning with the Edc
Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes-
Action-Tachometer has lost memory and is not aligning with the Edc Control
3. EDC:00961-01>hour-
4. EDC:00962-01>Day-
5. EDC:00963-01>Month-
6. EDC:00964-01>Year-
