Question about Ice Cream Makers
My ice cream pulp is no longer freezing when am producing, what should i do?
ThaMp3Doctor
  • 8596 Answers
SOURCE: ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Posted on Dec 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: ice cream not firm
The freezer bowl is sensitive. Go ahead and thaw it out until you can hear the liquid swishing around inside - usually letting warm water run through it is sufficient for thawing. Then refreeze the bowl, making sure the bowl is sitting flat/level in the freezer. When making ice cream with this unit, letting the freezer bowl sit out for even 20 minutes can unfreeze it enough so that you only get sludge. Do not remove the freezer bowl until you are immediately ready to pour the ingedients into the bowl. You can even pre-chill your ingredients by letting the ingredients sit in the freezer for about 15 minutes - although I have found that this usually has the opposite effect of what you have just experienced --> the ingredients usually freeze up so fast that the mixing paddle is no longer able to turn.
-Tha Mp3 Doctor
Posted on Mar 17, 2009
SOURCE: cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Posted on Jun 07, 2009
allabouttile
  • 11 Answers
SOURCE: I need Oster ice cream maker instructions
http://kitchen.manualsonline.com check out this website for your instructions.
Homemade Vanilla Ice Cream
3 cans fat free evaporated milk
1 quart fat free half and half
1 quart whipping cream
1 cup Splenda
vanilla to taste
Mix all together. Follow directions for electric ice cream maker. Makes 1 gallon. To make chocolate ice cream, add sugar free chocolate syrup in recipe.
Posted on Jul 31, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Posted on Sep 29, 2009
How long do I churn mixture?
Probably 15-20 minutes depends on machine and mixture. Some machines stop churning when the ice cream gets so thick that it stops the beater from turning. If you have this type of machine, when you hear clicks turn it off. If you start with a frozen container vessel, your ice cream will freeze faster. Remember that longer is not necessarily better. The longer it is out, the warmer it gets, and will turn back into slush.
Aug 28, 2016 | Ice Cream Makers
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
Welcome to FixYa
An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
Read Following ...
  • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
  • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
  • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
  • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
  • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
OR click here
Just Check this Link too
Thanks for Contacting FixYa...
Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
Ice cream not firm
-Tha Mp3 Doctor
Mar 16, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ice cream is soupy & when I freeze it it becomes icy
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Musso Ice cream maker freezes and then heats up during use
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Jan 14, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Ice Cream Makers Logo
203 people viewed this question
Top Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
