Question about Building Materials
I have a chamberlin garage door opener that works fine until the temperature drops to zero or below and then it goes part way down and then reverses itself and won't go down. Any idea of a solution?
  • 3,238 Answers
Check the light beam at the side of the doors are clean this would stop door going up and down.
Posted on Dec 10, 2016
When the temperature gets near or below zero, my door comes part way down and then reverses. It works perfectly at higher temps. do you have a solution?
I re-categoried this question, hope it was garage door related. There is an adjustment on the motor unit that sets the reverse threshold if the door hits something. When it gets cold, lubricants can get thicker and the door senses the resistance and opens when trying to close. You can change lubricants or set the adjustment to a higher setting
Dec 10, 2016 | Building Materials
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 1half h\p chamberlin garage door opener
Unplug the opener and remove the bulbs. Use a small screwdriver to pull out on the center contact in the socket. Make sure you are using standard bulbs.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unplug the unit and remove the bulbs. Using a small screwdriver pull out on the center connection in the socket.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Whenever the temperature drops below approx 40 degrees the door only opens anywhere from 12" to 3ft. The door works fine when the outside temp is above 40. When I unhook the door from the opener it moves...
Make sure there is no grease in the rails. This can congeal and cause this problem. The 'up force' control is on the panel where all those white wires go. You can try increasing this also.
Feb 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
When the temperature drops below 30 degrees F my garage door opener will not close the door. I tried adjusting the downforce but it still does not close. Craftsman 41A4315-7C
Put the down force adjustment back where it was as it affects the safety reversing. If the main light flashes 10 times when you try to close the door it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit if necessary. It could be an electronic component that is sensitive to cold and quits when the temperature drops. This is not uncommon.
Dec 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberline 1/2 horse truble shoot
check the infared sensors make sure those are working right. Yo may have to adjust the tension for bring down the door.usually a screw on the motor to adjust the senisitivity.
Oct 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Automatic Garage door reverses and automatically opens after closing
I can't believe it! My opener works fine a 10 degrees and above but below 10 degrees it would go down a little ways stop and go back with the light flashing. I checked the electric eye and found it would go out of alignment when the temp drop. Who knew!
I made the adjustment and it now works fine.
Jan 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
216 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
